car will not fire
Old Jun 14, 2012 | 02:01 AM
trill_ed's Avatar
Icon2 car will not fire
I 95 honda dx with a 97 civic vtec motor. I have changed ecu, ignition coil, and icm and I still get no spark. Could I have a bad distributor
Old Jun 14, 2012 | 02:16 AM
Kaleko's Avatar
Default Re: car will not fire
Have you tested for spark? I would also check the main relay.
Old Jun 14, 2012 | 02:59 AM
trill_ed's Avatar
I checked for spark with the screw driver in the spark plugs. I got no spark from none of them. I have not checked the relay yet
Old Jun 14, 2012 | 10:24 AM
kwijibodavid's Avatar
one ting that i would check because i had a d15b7 in my 94 hatch to a d16y8 out of a 96 ex hd no spark had no fuel pressure. the pump wasnt kicking in. what was causing that was bad piggy backs used a z6 intake/tb/inj allong with a z6 harness car fired right off
Old Jun 14, 2012 | 02:46 PM
trill_ed's Avatar
Ok I will check my fuel pressure and get back to u
Old Jun 14, 2012 | 02:54 PM
Nbboy7's Avatar
Are all your grounds wires good??
Old Jun 15, 2012 | 05:53 AM
simple way to see i yor getting fuel is to loosen the bango bolt on te fuel filter unde the hood and see if fuel comes out when yo put the key to the run position (make sure the clutch is in not sure if it matters but better safe then sorry) that is if u dont have a guage
Old Jun 15, 2012 | 06:46 AM
Former User's Avatar
What ECU?
CEL codes?
Does Blk/Yel wire attached to coil get battery voltage?
Does the fuel pump prime?
Old Jun 15, 2012 | 08:27 AM
trill_ed's Avatar
I was giving a p28 ecu. Sometimes the check engine light clicks while cranking sometimes it don't come on, but i did not check the codes. I haven't been home in a few days to check for fuel pressure. But would that really affect the spark.
Old Jun 15, 2012 | 08:36 AM
Crank the engine for 30 seconds and afterwards leave the key in the ON(II) position without turning it off. Then jump the service connector to check for CEL codes.
Rather than measuring fuel pressure, start by telling us whether the fuel pump primes for 2 seconds when the key is turned from off to ON(II).
Next check whether the Blk/Yel wire attached to the coil inside the distributor has battery voltage with key in ON(II).
Old Jun 15, 2012 | 11:42 AM
trill_ed's Avatar
I will check it tomorrow and get back to yall. Thanks for the help.
famdakam
Honda Civic (2006 - 2015)
Feb 8, 2017 05:19 PM
hcontreras
Dec 27, 2015 02:29 PM
1997boostedeg
Apr 15, 2012 11:15 AM
civic702
14
Jan 15, 2005 05:11 PM
Eg4-TuRbO
Jul 30, 2004 11:48 PM
