Mystery Bolt Hole
Old Jun 11, 2012 | 01:27 PM
SC_Yunzer's Avatar
Icon6 Mystery Bolt Hole
Hello, I recently purchased a 92 Accord 2.2. I noticed a water leak, and after researching where it was coming from I am stumped. It is leaking from a threaded hole near the rear timing balancer. I can not find the proper size bolt for it. M4 is too small, M6 is too big, M5 fit but the only thread pitch I can find is 0.8 and it will not thread in. In the photo below it is the bolt just above the black rectangle in the top center of the photo.
http://i37.tinypic.com/9h8cht.jpg
The head gasket, water pump, and timing belt were changed just before I bought it. any help would be appreciated.
Thanx
Old Jun 11, 2012 | 04:57 PM
jdmcertified909's Avatar
Default Re: Mystery Bolt Hole
isnt that the hole where you put a screw driver or something to hold a shaft in place?
Old Jun 11, 2012 | 05:03 PM
yeah its a bolt for the oil pump thats where you stick a screwdriver to stop the oil pump pulley from spinning when removing it
http://www.vadriven.com/forums/tech-...cement-306594/
Old Jun 11, 2012 | 05:07 PM
Thepowderblue's Avatar
No and NO! its to lock the rear balance shaft on tdc
Old Jun 11, 2012 | 06:19 PM
MAD_MIKE's Avatar
MM Gruppe B
THIS.
That bolt hole is in the block not the oil pump housings.
Looking up Honda parts via Majestic the bolt does not appear to be available.
See if you can find that tools thread pitch, or just go to a PnP yard and get it off a dead 2.2.
I don't recall the bolt being anything special, thought it was the same as the timing belt cover bolt(s), but it's been a while since I've been under a Honda.
Old Jun 11, 2012 | 07:01 PM
yeah that my bad
Old Jun 12, 2012 | 04:18 AM
SC_Yunzer's Avatar
Thanks for the info.
Turns out it is the weep hole for the water pump. So now it looks like i know what im doing this weekend.
Old Jun 12, 2012 | 10:48 AM
that is not a water pump weep hole the weep hole is on the water pump it self you might not see it the water pump pulley is in the way that hole is to lock the balance shaft when removing it
Old Jun 12, 2012 | 10:59 AM
ok were all wrong. i cant believe it took me this long to notice that the reason the balance shaft bolt is missing is because the timing belt is off. your talking about the actually leak at the weep hole. i did not see the anti freeze residue. it was hardly noticeable. im sorry for the confusion we may have caused you
Old Jun 12, 2012 | 11:25 AM
redbull-1's Avatar
Thepowderblue and MAD_MIKE were not wrong as they thought the OP was referring to the hole with the threads. One of the two weep holes on the pump is shown.
Old Jun 14, 2012 | 05:16 PM
Lost Again's Avatar
"This dude is out of sight, everything he does, seems to come out right"
Good to see you around again
Ran4it2
12
Feb 24, 2009 04:24 PM
jaysome01
Oct 9, 2007 08:38 AM
DevineEntity
Aug 22, 2006 03:46 AM
gnar kill
Mar 29, 2005 01:14 PM
Kamin
Jan 23, 2003 04:22 PM
