Mystery Bolt Hole
Mystery Bolt Hole
Hello, I recently purchased a 92 Accord 2.2. I noticed a water leak, and after researching where it was coming from I am stumped. It is leaking from a threaded hole near the rear timing balancer. I can not find the proper size bolt for it. M4 is too small, M6 is too big, M5 fit but the only thread pitch I can find is 0.8 and it will not thread in. In the photo below it is the bolt just above the black rectangle in the top center of the photo.
http://i37.tinypic.com/9h8cht.jpg
The head gasket, water pump, and timing belt were changed just before I bought it. any help would be appreciated.
Thanx
Thanx
Re: Mystery Bolt Hole
yeah its a bolt for the oil pump thats where you stick a screwdriver to stop the oil pump pulley from spinning when removing it
http://www.vadriven.com/forums/tech-...cement-306594/
MM Gruppe B
THIS.
That bolt hole is in the block not the oil pump housings.
Looking up Honda parts via Majestic the bolt does not appear to be available.
See if you can find that tools thread pitch, or just go to a PnP yard and get it off a dead 2.2.
I don't recall the bolt being anything special, thought it was the same as the timing belt cover bolt(s), but it's been a while since I've been under a Honda.
Thanks for the info.
Turns out it is the weep hole for the water pump. So now it looks like i know what im doing this weekend.
that is not a water pump weep hole the weep hole is on the water pump it self you might not see it the water pump pulley is in the way that hole is to lock the balance shaft when removing it
ok were all wrong. i cant believe it took me this long to notice that the reason the balance shaft bolt is missing is because the timing belt is off. your talking about the actually leak at the weep hole. i did not see the anti freeze residue. it was hardly noticeable. im sorry for the confusion we may have caused you
Thepowderblue and MAD_MIKE were not wrong as they thought the OP was referring to the hole with the threads. One of the two weep holes on the pump is shown.
Ran4it2
12
02-24-2009 04:24 PM
jaysome01
10-09-2007 08:38 AM
