no speedo after driving with vss unclipped?
Old Jun 8, 2012 | 04:53 PM
SiRCiviC94's Avatar
Default no speedo after driving with vss unclipped?
weird I changed the trans oil and unclipped the sensor but then decided to just use the fill hole. drove off and noticed no speedo, O-k plug in the clip. still no speedo ??? anyway now the speedo doesnt work on any of my ecu's the fuse is fine idk how thats possible?
my current ecu throws a code for traction control id like to know if there is any affect on power because of that? I dont want to run a stock ecu if anyone reading knows
1998 ek hatch 1996 gsr swap stock with 3 computers. currently on a p28/ gsr program, have obd2 p72 and a p30
Old Jun 8, 2012 | 04:58 PM
Blacknight117's Avatar
Default Re: no speedo after driving with vss unclipped?
Can`t help ya if you don`t tell us what kind of car you have...
Old Jun 8, 2012 | 05:31 PM
SiRCiviC94's Avatar
fully forgot thanks! I will be trying a vss out of an ls integra asap
Old Jun 8, 2012 | 05:36 PM
Former User's Avatar
Fuse 15 blown?
Old Jun 8, 2012 | 07:13 PM
SiRCiviC94's Avatar
No. And this is bs because I got the cel out now! Need this done! :D
Old Jun 8, 2012 | 07:30 PM
When you turn the key from off to ON(II), does the charging system light (battery symbol) turn on and stay on?
Old Jun 11, 2012 | 11:08 AM
SiRCiviC94's Avatar
i took the 3 philips head screws off and pulled the sensor, its a spring with a top that spins on the sensor plate which has a spinner and a T which goes into the trans which spins with the wheels. all installed properly. the clip has voltage like 3v. so wtf. im going to pull another one and hope itll fit from a teg. they look different.
the battery light stays out. no CEL.
.... pissed.
Old Jun 11, 2012 | 01:12 PM
noz79's Avatar
Those VSS can be tricky sometimes if you just re-install it it'll work just fine.
Last edited by noz79; Jun 11, 2012 at 03:04 PM. Reason: Updating pictures to 96-98 Civic
Old Jun 11, 2012 | 01:23 PM
These^ two pieces of information are consistent with 7.5A dash fuse 15 being blown.
Old Jun 11, 2012 | 01:24 PM
The diagrams you posted are for 92-95 Civics. The OP has a 98 Civic.
Old Jun 11, 2012 | 02:07 PM
SiRCiviC94's Avatar
I put it back together made the post and had low confidence but it now works! no CEL and a fully working engine stock. thanks for all the help.
my idle is still 1100 and will not budge at all lower. tried 2 iacv the only other thing is to try another tps? cable is loose as fk
Old Jun 11, 2012 | 02:55 PM
noz79's Avatar
Your right. Colors are going to be different. Ill change it to 98 for future searches
CiViCShella
May 2, 2013 01:44 PM
ONEhaque
Nov 4, 2008 06:31 PM
turismo128
Sep 27, 2005 03:22 PM
jdmjay04
Mar 29, 2004 11:13 AM
90civichbsi
Mar 19, 2004 04:33 AM
