zc sohc on jrsc 7psi
Old May 31, 2012 | 10:41 PM
carbon fiber coupe's Avatar
Default zc sohc on jrsc 7psi
I may be needing a basemap/p28 chipped and what not for my car. really wanting to get rid of my fmu (i know i know, but i dont beat on the car or anything)
where is the right place to go? no one in my area does anything b/c no one has one
Old May 31, 2012 | 11:04 PM
Dc4LsTeG's Avatar
EK9
Default Re: zc sohc on jrsc 7psi
You asking where to get a basemap/chip done to your ecu? Look into Phearable
Have you looked into Hondata/Neptune/Aem?
mtber's Avatar
Once you remove the fmu you will need to run a standard 1:1 fuel regulator and the correct size injectors & fuel pump.
You will also need to either find another stock map sensor or make a block off for where the current map sensor is. The reason for this is due to the map sensor needing to run off a vacuum line on the back of the supercharger so that it can see positive manifold pressure.
Concerning ecu chipping & pre-chipped ecus, there are several vendors.
You are more then welcome to check my signature :-)
Old Jun 5, 2012 | 07:47 PM
monkeerench's Avatar
Hi I have a d16z6 with a jsrc. Socket p28 ECU. Map sensor
moved to after charger. I used a base map found on the net.
It for 1.6z6. Jsrc with rc 440 injectors. Now the car runs 10.3:1.
I m still trying to figure it out. So becarefull were you get your base from.
But I'm sure you know that.
Old Jun 10, 2012 | 10:59 AM
HCivExoo's Avatar
well no two motors are exactly the same. Maybe your SC isn't pushing as much air as the original car as the basemap was on. Who Knows? Also a basemap is exactly that, a BASE map.
I know the basemap that came with my S300 was the same way and I am also in process of taking away some fuel to get my A/F ratios out of that 10:1 rich area. get a wideband and start logging to get your set up running right.
Old Jan 3, 2013 | 09:35 PM
I currently running the stock injectors
and got it through emissions testing.
Modz+Civic= <3
Engine Management and Tuning
Oct 5, 2012 07:15 PM
sixfourkiller
Jan 3, 2011 09:36 AM
blkb18
Dec 25, 2007 07:23 AM
ebp 99 si
Mar 18, 2004 12:33 PM
rebohn
Dec 18, 2003 12:00 PM
