3bars map sensor GM
3bars map sensor GM
i have 3bar map sensor gm but i want to know the hardware to install it somebody talk about hondata run only with hondata ? other question what happed if i put turbo chip on my p28 ecu? to use the 3 bars?
Re: 3bars map sensor GM (rebohn)
if you replace the map sensor then that solves your problem of running check valve's or what not. as far as runing a turbo chip on your car i dunno WTF your talking about. You can run bigger injectors, FMU and feul pump and tune it with an apexi safc or what not. But serously search, i was looking into turboing for a while and any and every method that you could want or possibly run has been covered in here.
SEARCH, also check out the FORCED INDUCTION fORUM
yes i want intall the 3 bars sensor but i want to know the hardware to install the map sensor i try but check engine its on what can i do?
