Map sensor ?
Old Dec 24, 2007 | 06:11 PM
blkb18's Avatar
Default Map sensor ?
I am gathering parts for my jrsc gsr build. The motor will be rebuilt, all stock internals except for arp rod bolts, head studs and adj. cam gears. Will be running s300 p28 with 440's and a wideband. Can I run the stock map sensor? Is there any advantage to changing it? Thanks in advance.
Old Dec 24, 2007 | 06:19 PM
TheShodan's Avatar
Moderator
Default Re: Map sensor ? (blkb18)
If you plan on going over 11psi of pressure with the JRSC build, only then would it be necessary on the Hondata. Otherwise, no.
Old Dec 24, 2007 | 07:52 PM
mtber's Avatar
The stock map sensor will be fine to 11 psi as stated before.
Make sure you relocate the map sensor to use a vacuum source on the back of the jrsc so you are seeing positive manifold pressure.
Old Dec 25, 2007 | 07:23 AM
blkb18's Avatar
Default Re: Map sensor ? (mtber)
Thanks for the info guys, happy holidays.
import-tooner
Jan 18, 2011 07:43 PM
sixfourkiller
Jan 3, 2011 09:36 AM
jakeiscool
Nov 16, 2005 06:54 PM
93supercoupe
Feb 10, 2005 02:29 PM
deez92
Aug 8, 2003 07:37 AM
