Transmission or electrical?
2005 Accrod EX/ 2.4/ 190,000
During hard acceleration, if I put the pedal down, the tac goes to 3000rpm and I have no power.
If I accelerate moderately, I have no power and the tac dances from 2000 to 3000 rpm.
I I accelerate slowly, the car gets up to 70 with no problem and no hard shifts.
Check engine light is on. Thermostat out of range and O2 sensor slow.
Any info would be greatly appreciated. In the 7 years that I have had this car, I have never had it in the shop. I try very hard to maintain and service myself. I would like to keep that going.
PLEASE HELP!
__________________
2005 EX 5 Speed Automatic
Ext. Color: Nighthawk Black Pearl
Int. Color: Ivory
Engine Type: In-Line 4-Cylinder
Engine Block/Cylinder Head: Aluminum-Alloy
Displacement (cc): 2354
Horsepower @ rpm (SAE net): 160 @ 5500
Torque (lb.-ft. @ rpm): 161 @ 4500
Bore and Stroke (mm): 87.0 x 99.0
Compression Ratio: 9.7 : 1
Valve Train: 16-Valve DOHC i-VTEC®
PLEASE HELP!
__________________
Int. Color: Ivory
PLEASE HELP!
__________________
Int. Color: Ivory
PLEASE HELP!
__________________
Int. Color: Ivory
https://honda-tech.com/forums/acura-rsx-dc5-honda-civic-ep3-32/p2647-causing-limp-2775336/
It could be this. Check out this post above. My 06 Accord is having the same issue Do you have an OBD2 reader you can hook up to your car to confirm the code?
jabermalandi
Apr 29, 2014 06:17 PM
johnk
Sep 26, 2009 09:52 AM
trellend
Apr 5, 2007 05:01 PM
