Need Help With Clutch issues
so all day today the clutch was perfect to slips no nothing. no issues. i get out of work start my car then go to put it in first the clutch is all loose to almost the floor, barely have to push it. then right before the floor(1-2inches) it gets hard. then its super difficult to put into first gear and when i finally get it in, it continues with all the other gears all the way home. i dont know much about transmissions. or what this could possibly be, so any help would be greatly appreciated..
thanks in advance
97 civic, 4 door lx if that helps
thanks in advance
Prolly the slave cylinder on the tranny bellhousing area..or the master cylinder on the firewall where the fluid goes...speaking of fluid, is there any in the clutch reservoir?
tbh its dark as hell out right now and ill check the reservoir in the early AM. im not 100% familiar with all the bells and whistles of the transmissions and clutches things.
i should start with the reservoir first, and make sure there is fluid?
HELP: Came out to car this morning, clutch floppy, won't engage, completely out of fluid, filled sti
Kristo92
Jun 30, 2004 02:06 PM
