pinging
Old Oct 13, 2002 | 06:18 PM
Pepsi90919's Avatar
Default pinging
my 91 civic has a lot of pinging when the revs get up a little bit. it happens more when the engine gets hot. i'm being told i have no EGR on this engine, so how exactly does it replace the cooling effect of the egr!?!
i ran NGK g-power spark plugs for about a month and other than being worn down a bit they looked in perfect condition when i took them out.
what's the deal?@
Old Oct 13, 2002 | 06:49 PM
GZERO's Avatar
Default Re: pinging (Pepsi90919)
pinging as in knocking?
Old Oct 13, 2002 | 06:56 PM
Pepsi90919's Avatar
you're on the right track, but pinging as in pinging.
Old Oct 13, 2002 | 07:06 PM
GZERO's Avatar
well, i can think of two things right away, the plugs might be too hot or the timing is off, check that first, but it sounds like it has to do with timing
Old Oct 13, 2002 | 07:11 PM
n2ohuffer's Avatar
Default Re: pinging (GZERO)
yeppers, it's called detonation...Us nitrous folks are familiar with it it's a timing issue, and sometimes shi**y gas...
Pepsi90919 pt2's Avatar
the timing is fine and i already talked about the plugs. right now it has the stock-spec NGK's in there.
Old Oct 13, 2002 | 07:25 PM
GZERO's Avatar
Default Re: pinging (Pepsi90919 pt2)
i'm not familiar with engines that doesn't have EGR so, i'm sorry
Old Oct 16, 2002 | 11:10 PM
AWD: Jeff's Avatar
how does this pinging noise sound like?
Old Oct 17, 2002 | 09:37 AM
93_civic_EX's Avatar
Default Re: pinging (sohc93hatch)
u do know that all honda motors have a ticking noise from the valves, right......
no matter its either low octane fuel or the timing is off like everyone else is saying
[Modified by 93_civic_EX, 1:40 PM 10/17/2002]
Old Oct 17, 2002 | 10:12 AM
The_Oz's Avatar
Default Re: pinging (93_civic_EX)
Actually, the ticking are your injectors...not your valves (provided the valves are adjusted properly).
Regards,
Oz
SoHc94
22
Aug 26, 2006 09:18 PM
Integra21
Mar 29, 2006 03:05 PM
92integraVTECgsr
Sep 26, 2005 04:01 PM
sohcvtec1995
Sep 19, 2004 12:13 PM
1sick4door
Feb 14, 2002 09:39 PM
