going nuts!! code 4 on obd1?
Old May 16, 2012 | 09:23 PM
2ndteg2turn9sec's Avatar
Default going nuts!! code 4 on obd1?
I have a 97gs integra with a 0bd2 to obd1 conversion harness running on a chipped p-28 ecu with a b18b chip. Also the car has a obd2 engine harness. So I just finished the swap start it up an. I see a cel so i jumped the wires an I get code 4. I thought code 4 was ckp for only obd2? Car runs fine execpt it won't go past 3.5k. So I turn the car off then turn it back on an the cel is off an the car revs normal. Turn car back on an cel is now back on. I just don't get it. Has anyone had this happen in the past? I've searched but all I get is threads that never were answered. Actually did the swap back in january an the car has been just sitting because I haven't got the time to bleed the clutch an all. Could anyone answer this?
Old May 17, 2012 | 04:17 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: going nuts!! code 4 on obd1?
That is a distributor code not the crank sensor by the crank.
Old May 17, 2012 | 05:39 AM
Technical Hero
Old May 17, 2012 | 07:40 PM
I have an obd2 dizzy so wouldn't the dizzy not have a crank sensor in there? Or do I have to get an obd1 dizzy to make it work. On my old 98 gsr I converted it to obd1 an I used a obd2 dizzy.
Old May 17, 2012 | 10:06 PM
civickiller's Avatar
obd2 distributor works fine with obd1 ecu
codes 4,8,9 all distributor
Old May 17, 2012 | 10:07 PM
Fliptard's Avatar
Your ECU and DIzzy have to be the same OBD. Get an OBD1 distributor.
Old May 17, 2012 | 10:28 PM
really? i had 2 cars running obd2 distributors and obd1 ecus.
this may also blow your mind but i was running a ls distributor on my gsr head
Old May 17, 2012 | 11:56 PM
Hyper16-Johnny's Avatar
This statement is untrue! OBD2 dizzy with OBD1 ecu on all the ODB2 cars I've worked on, including mine.
Old May 18, 2012 | 04:47 AM
Technical Hero
Yes that statement is untrue. You can interchange OBD1/2 distributors with no issues. The issue comes with OBD0 and OBD1/2 ECUs and vice versa. Yes the OBD2 distributor has the same sensors inside. The only real difference between OBD1/2 is the plug style.
Old May 18, 2012 | 08:16 AM
Well I do have an obd2 vtec dizzy laying around so would I beable to just pop that on or do I need a non vtec dizzy?
Old May 18, 2012 | 09:29 AM
the only difference between vtec and nonvtec distributors is the ears placement.
pop that distributor on there if it fits, idk if any of the ears will be in the way
Old May 18, 2012 | 10:25 AM
Ya it don't fit. Right now I'm swapping over internals to make the ls one work.
Old May 18, 2012 | 11:27 AM
mouab18c1's Avatar
Are you sure it's the distributor that is bad? It could also be the ecu. I have thread related to this exact problem. Too lazy to find it but just look up my threads.
Old May 18, 2012 | 01:42 PM
With the same ecu the type r engine I had in there before I no zero issues with it. Only thing that's weird is when you turn on the ignition without the engine on there is no check light on the dash like normal. Idk it could be bad but if it is I'm just pulling the engine an swapping in an h2b setup like I have planned a few months down the road. The ls engine is just a temp engine untill I get an h22 from from hmo. Gotta wait untill Tuesday to get a new dizzy because in order to swap out the internals I gotta swap everything like the coil an such. To much of a pain
Old May 18, 2012 | 02:16 PM
oh yeah i had a code 8 before, after of about 15 minutes of driving thats when i got the code 8, new distributor fixed that.
sikcrx80
May 1, 2023 05:16 PM
BradEK9
May 14, 2014 05:50 PM
beseman
Aug 24, 2006 10:18 AM
john d
Oct 6, 2004 08:03 PM
