Tial bov spring help
Gettin ready to purchase this bov, just need to know what the spring rate is indicated for and does it matter on which I should get. Thanks!
Oh ya
Should I base the spring rate off hp
Oh ya
My Tial 50mm bov came with a -7psi spring (black) and I traded it for the -11psi (unpainted) spring. This solved my compressor surge I had at light boost blow off with the black spring.
One needs to check their vacuum to determine what size spring is needed.
http://www.tialmedia.com/documents/BOVspc.png
For most hondas -11psi spring is to be used.. (Yes, even if you're running under 10psi of actual boost pressure.. its not based upon the amount of boost pressure you're going to run.)
