Turbo build part thread #893989483
I am about to purchase a b18b1 block tomorrow to start a motor build.
First off, I plan on having a shop rebuild a block, install rods, rod bolts balance crank shaft, and anything I should have done to the block primarily with the turbo build in mind, of course I'll get a new oil pump wp etc.
My goal for power is 350-400whp. This will take a long of knowledge, time, and money to get there, but this is the start.
My question, do I really need aftermarket pistons? What reasons are there to get different pistons, change the compression ratio? Strength in the piston itself? Should I change the compression? Can I run stock pistons? Pretty much I don't want to sleeve it. I'll sleeve it once I crack one.
Why a b18b1? Price. Cheap. I don't want vtec, I want the torque of non v tec, same with the head. ~Opinions wanted, will not go vtec
Anyways, I plan on purchasing rods, rod bolts, arp head studs, a good head gasket, probably rebuild a head, or port one?
Will a 38mm wastegate be suitable for this power?
Thanks for any info.
will take a lot more boost pressure to get that same goal, so be ready to push.
