Bottom end build
Old Mar 8, 2009 | 10:21 AM
UserX826's Avatar
Default Bottom end build
tried seraching.. i dunno. i'm positive it's there but i didn't see it
Just wondering what components are most important when building a block/head for boost..
I'm probably going to build a gsr block and head
Old Mar 8, 2009 | 10:42 AM
marcj's Avatar
Default Re: Bottom end build
rod bolts, head bolts and pistons
Old Mar 8, 2009 | 11:56 AM
Schister66's Avatar
Man U FTW
Well the typical build is just pistons and rods. I have my goals listed in my sig. When i built my setup, i got a set of 9.8:1 Arias pistons and Eagle rods. I also got a new HG, oil pump and water pump while it was apart. The head is still stock...your build really depends on your goals
Old Mar 8, 2009 | 12:18 PM
jdm602's Avatar
this one guy put down 507 wheel on a stock b16 with just some arias 9:1 pistons and thats it. even reused stock headstuds and bearings lol.
Old Mar 8, 2009 | 12:33 PM
SD_Lurker's Avatar
HT White Ops
Rod Bolts? Are you serious? This isn't a NA build. I would never recommend stock rods on a boosted build with rod bolts..
Old Mar 8, 2009 | 12:46 PM
egb18c5's Avatar
^lmao
Old Mar 8, 2009 | 01:26 PM
Milab21's Avatar
What power goals are you going for? Will this be a daily driver or a track beast?
Old Mar 8, 2009 | 01:43 PM
marcj's Avatar
I'm just listing those as THE BARE MINIMUM. you could easily make enough power for any street honda with the fore mentioned if you know what you're doing.
Old Mar 8, 2009 | 02:32 PM
Silva Bullit DC4's Avatar
Yes, thats true. But he did not state his power goal. He may not want just the "bare minimum", that will depend on his power goal, and what exactly he wants to do with the car.
Old Mar 8, 2009 | 02:33 PM
EARLdaSQUIRREL's Avatar
official honda whore
get the block and head resurfaced
eagle rods
9:1 cp pistons (81.5mm)
block bored/honed to piston specs
oem rod/main bearings and thrust washer
new oil pick up gasket
new oil pan gasket
new head gasket
arp head studs
new rear main seal
new water pump
new timing belt/tensioner
and that should be it
add a 57 or 60 trim turbo and you have a 400whp pump gas street car
Old Mar 8, 2009 | 10:32 PM
UserX826's Avatar
sorry. should've said my goals.
Wanting to be able use it as a DD, but at the same time be able to up the boost and put up 250-300 for autox..
Also.. Any suggestions for head work? will injectors, cams, porting matter?
Old Mar 8, 2009 | 10:54 PM
UserX826's Avatar
and, while i'm at it, how is compression ratio directly related to power? to stability?
Old Mar 8, 2009 | 11:26 PM
jdm602's Avatar
lower compression you can run more boost to make power but higher compression you can run less boost and still make power but risk detonation...unless your cool and run a different kind of gas...ethanol cough cough.
but if you only want 250-300...i wouldnt bother in wasting money on the bottom end to make that. it can eassily be done on pump gas with a decent setup...and still have it be reliable.
Old Mar 8, 2009 | 11:29 PM
UserX826's Avatar
yeah. i said 250-300 thinking it would be safer... I'd like to get as much as possible, but i don't want to blow my damn car up.
after looking here https://honda-tech.com/forums/forced-induction-16/post-your-turbo-gsr-hp-numbers-1501150/, it seems like if i run eagle rods and 9:1 pistons i could be running 250-300 safely as a dd...
Old Mar 8, 2009 | 11:32 PM
jdm602's Avatar
i know about 6 people in my area that are putting down over 300 wheel on a stock bseries. 3 of them are putting over 400. one is at 460 wheel. and his girlfriend dailys it too.
but to each his own. eagles and 9:1's should do that easily.
Old Mar 9, 2009 | 04:38 AM
marcj's Avatar
for 250-300 do like I said in the first place.. replace the pistons, maybe the rods.. make sure you replace the rod bolts and head bolts with ARP. an oem headgasket and you'll be good to go.. also a set of DSM 450cc's, fuel pump and a good tune
civicboy07
Oct 14, 2013 11:34 PM
tealsvteceg
Feb 14, 2008 08:27 PM
lakai_19
Jan 28, 2007 08:22 PM
RACEPAK
Aug 21, 2005 09:09 AM
LSVTEC 91 Civic
30
Mar 29, 2005 05:40 PM
