Help on Turbo Build
Hey guys im going to start a turbo build very soon. I am going to use it as a daily driver. I am looking for about 300whp maybe a little less.
My question is what do i have to do to the block to make it the strongest, just to be on the safe side. I have a JDM B18c ( GSR-R). But as of now i am going to be driving a Single Cam. I was gona redo the whole block. The head already has springs and retainers and Skunk2 Tuner 2 Cams.
I was going to put in:
Aftermarket Pistons IDK whick brand (10:1 COMP)
Eagle Rods
Bearings
Piston Rings
.50 or .60 Trim turbo? someone shed some light on this
AND.....
What else for the block so i dont blow anything up.
Eagle Rods
Bearings
Piston Rings
AND.....
300 whp is completely possible on a stock B series block. With new internals you should be more than safe at that range assuming a good tune.
The size of the turbo will depend on where you want spool and what your maximum power goals are. CFM are more important than trim.
Start at the top of this page https://honda-tech.com/forums/forumdisplay.php?f=16 << it should look very familiar to you
Edit.. this read is a little outdated, but explains alot. FMU's and other little things arent used anymore.. just read it http://www.beesandgoats.com/boostfaq/g2icturbo.html
Bulldogg83
Oct 15, 2003 11:06 PM
