Mystery compressor surge, experts chime in!
Old Apr 16, 2012 | 07:09 PM
TravisBiggie's Avatar
Icon2 Mystery compressor surge, experts chime in!
I've done everything under the sun to get rid of my surge, yet it still lingers.
First, I have a legit greddy and a knock off greddy, both produce compressor surge even at the softest setting, I've tried every setting you can do. (the valve does open a lil but with little bits of reving)
I connected to the brake booster, no change. The PCV port on the intake manifold, nothing. Moved the BOV from before the TB to inbetween the turbo and IC, NOTHING!!!!!!! Boost gauge reads constant -20 at idle.
Hoses are brand new, just inspected them for tares/cuts
My old thread for more info
Old Apr 16, 2012 | 10:16 PM
W!d3b0dYr3X's Avatar
Default Re: Mystery compressor surge, experts chime in!
donno what to tell you on how to fix the problem, but i have read many threads and seen first hand that greddy bov's do have surging issues. maybe you should look into another bov?
maybe someone else can chime in.
Old Apr 16, 2012 | 11:31 PM
TheShodan's Avatar
Moderator
its not a "surge" issue. People tend to confuse actual compressor surge with simple BOV flutter from low boost pressure, (such as just over vacuum). I still think the OP needs to get a video of the turbo under some engine load to confirm that its true compressor surge (usually comes after the valve pops off slightly) before going through the expense and time of changing BOVs.
Old Apr 17, 2012 | 02:00 PM
http://www.youtube.com/watch?v=7dCjVpJfno8
here U go Shodan. This is with the BOV next to the TB, and the surge came from the other side, where the turbo is. I have not tested the NEW bov on the throttle body side, but it shouldnt matter cause i'm still fluttering with both blow off valves.
http://www.youtube.com/watch?v=vSkFDcmqIXU
I also hooked up another vac line to see if it would do anything, but nothing changed.
Old Apr 17, 2012 | 05:00 PM
nealnanoHX's Avatar
Yeah I can hear no compressor surge in those vid. I do here the BOV hiss. I also had a Greddy Type S and a Type RS they will flutter a bit under lower boost as Shodan said.
My MK3 Supra had compressor surge from the stock bypass valve dieing and the best way to describe it is a sick dieing dog barking.
Adding 2 vacuum lines will do nothing. Vacuum is vacuum. T-ing into the FPR line is how most do it and that works well. Also moving the BOV also really will have no effect on surge.
Old Apr 17, 2012 | 07:00 PM
TheShodan's Avatar
Moderator
I would find a better stronger vacuum line itself. make sure it isn't collapsing
Second, I'd find a better source, as it seems as though the valve is barely opening. Go from some source off the brake booster or IM, and not the gate or somewhere PRE-turbo.
But in either video, its not compressor surge. In fact, the first video shows no vacuum. The engine must be under load (which you showed in the second video), but its still not compressor surge. the valve just isn't opening
Changing locations doesn't help you either.
Old Apr 19, 2012 | 09:50 PM
compressor surge or just low psi flutter? greddy BOV
http://www.youtube.com/watch?v=zsPaTHomCeA
Old Apr 20, 2012 | 07:21 AM
nealnanoHX's Avatar
That is the sound of the Greddy BOV. Your compressor is not surging. Like I said it sounds kind of like a sick dieing dog barking.
Old Apr 20, 2012 | 07:39 AM
Hidenplanvew's Avatar
sounds normal to me
Old Apr 20, 2012 | 07:55 AM
b20ricepower's Avatar
Yeah its probably just the bov and fairly low boost causing it to flutter. If the vaccum line isn't collapsing then it should be fine. Just the way it sounds. If you wanna go with a quality bov and don't like the fluttering go with a synapse bov. They are close to 200 dollars but are totally worth it imo. They are probably the best bov to get rid of the fluttering and have a super quick response
Old Apr 20, 2012 | 07:57 AM
boosted_D's Avatar
sounds ok/normal to me as well.....have you ever heard an hks sequential bov at low load blow off? they sound a lot like surge, which is nothing like you noise....
Old Apr 20, 2012 | 09:27 AM
Slacker93eg's Avatar
10 Year Member
Here ya go
Old Apr 20, 2012 | 11:03 AM
I saw that video. Before I know I had true compressor surge, I'm happy to see all the replies, thanks guys.
Can anyone hear a boost leak?
blackeg
Dec 4, 2008 04:50 PM
hb_guy
Mar 31, 2008 11:59 AM
blinx9900
Jan 6, 2008 11:20 AM
tegon-gsr
Apr 7, 2005 07:02 PM
VTC_CiViC
Oct 26, 2001 04:47 PM
