GReddy Type S BOV Q..?
Old Oct 25, 2001 | 09:56 AM
VTC_CiViC's Avatar
Default GReddy Type S BOV Q..?
Quick question I asked before but I don't think anybody noticed since it was at the end of another discussion. I notice that my GReddy Type S BOV has to vaccum outlets. The top one I use and is tapped into the intake mani, the bottom one though is left open and unused. Is this a normal setup? The guy who set my turbo up mentioned something about the second being for high boost or something like that, but I don't remember for sure. Any thoughts?
Old Oct 25, 2001 | 10:59 AM
turbosol's Avatar
Default Re: GReddy Type S BOV Q..? (VTC_CiViC)
You can connect it to a boost source, such as right off the compressor housing, and it will increase the response on the BOV, but you don't have to use it.
Old Oct 25, 2001 | 11:58 AM
Adi Radoncic's Avatar
On Fire!
Default Re: GReddy Type S BOV Q..? (turbosol)
Leave the botom one open, its a lot more fun that way.....
and don't ask me why....
Old Oct 25, 2001 | 12:47 PM
VTC_CiViC's Avatar
Default Re: GReddy Type S BOV Q..? (newgsr)
Dammit.. WHY!? No really.. why???????????
Old Oct 26, 2001 | 12:05 AM
On Fire!
turbosol is right!!
Hook up the lower port to a source of boost as it significantly improves response of the bov.
Now if you need more info than that you better call greddy them selves
Old Oct 26, 2001 | 06:32 AM
VTC_CiViC's Avatar
Nono, I just wanted to know why it was left open and if I should use it, guess I'll "T" it into the line going to the boost solenoid from the turbine housing. Thanks
Old Oct 26, 2001 | 07:26 AM
TurboR1391's Avatar
I run the second vacuum source open and it works fine
Old Oct 26, 2001 | 04:23 PM
turbod97ex's Avatar
New User
Here is Greddy's response to what to do:
The top nipple on the top section will connect to your intake manifold (so it reads both vacuum and pressure and does not get bled off to anything) While the lower fitting is a vent for the internal diaphragm This one should be left open and not connected to anything.
Make sure when you adjust the stiffness of the valve that you first loosen the lock nut before you adjust the set screw. Adjustment will very from car to car, so you need to use trail and error. Generally you want to valve as tight as possible, without getting any compressor surge. You don't want it too loose or it can open too early and you will loose boost. The valve should make one clean blowing sound, it should not stutter. It should also not open before the throttle is shut.
Old Oct 26, 2001 | 04:47 PM
VTC_CiViC's Avatar
Default Re: GReddy Type S BOV Q..? (turbod97ex)
Ahh so it should be open after all. Thanks turbo
Crasian
May 10, 2006 11:14 AM
Integra21
Jun 8, 2005 02:16 PM
hovic
Oct 4, 2004 01:31 PM
vet_girl
Dec 26, 2003 03:14 PM
bumsta217
Sep 29, 2003 04:01 PM
