compressor surge with greddy RS, im really getting annoyed here!!
isent the greddy RS supposed to be a good bov? apperantly not! i have it set all the way soft and no matter what the turbo surges, it surges at low boost (2-5psi) it surges on high boost (15-20psi) and im getting pissy here. i was gonna just open it up and take out the stiff spring, but then i was worried it might open when i hit my target boost of 15psi.
turbo is a GT3076R, i used to have a t3t04e and i had the same problem with the RS valve.
any opinions here? sorry for the rant.
the bov opens, but i still get surge.
I had the same problem with the greddy type RS bov. It wouldn't open no matter how soft the setting was so I took one of the spring out and it worked fawlessly eversince.
Re: compressor surge with greddy RS, im really getting annoyed here!! (TDogg Teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TDogg Teg »</TD></TR><TR><TD CLASS="quote">What kinda vacuum source are using for the BOV?</TD></TR></TABLE>
its off the intake mani i believe.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by da_dude »</TD></TR><TR><TD CLASS="quote">I had the same problem with the greddy type RS bov. It wouldn't open no matter how soft the setting was so I took one of the spring out and it worked fawlessly eversince. </TD></TR></TABLE>
how much boost where you running?
I tell doctors what to do
Re: compressor surge with greddy RS, im really getting annoyed here!! (blinx9900)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blinx9900 »</TD></TR><TR><TD CLASS="quote">
how much boost where you running?</TD></TR></TABLE>Take the stiff spring out, it'll work. It works with all the knockoffs anyway. I've got a type s knockoff and I had to cut the spring to get it to work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blinx9900 »</TD></TR><TR><TD CLASS="quote">how much boost where you running?</TD></TR></TABLE>
Off wastegate spring @ 13 PSI.
Re: compressor surge with greddy RS, im really getting annoyed here!! (ILcrxsi1)
ok, im gonna just take out the stiff spring and see what it does, if im not happy im just gonna buy a new tial
UPDATE
its official, the greddy RS is garbage in my book now.
i removed the stiff spring, not only did it still surge but it wouldent hold boost above 8psi either (yes i adjusted the **** to stiff and it still wouldnt hold boost).
so then i put the stiff spring only in there, same deal, it was either surging or it wouldent hold boost, i just got pissed off and put the dual springs back in there.
GREDDY bov SUCKS
tial here i come
GREDDY bov SUCKS
tial here i come
Man U FTW
The RS has a tiny valve...i could have told you that on higher boost with a reasonably large turbo that it is going to surge. The ONLY way to avoid surge with that small of a BOV is to put it as close to the turbo as possible....much like the intercooler mounted Tials that some people run
Re: (Schister66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 »</TD></TR><TR><TD CLASS="quote">The RS has a tiny valve...i could have told you that on higher boost with a reasonably large turbo that it is going to surge. The ONLY way to avoid surge with that small of a BOV is to put it as close to the turbo as possible....much like the intercooler mounted Tials that some people run</TD></TR></TABLE>
is the RS really that small thanks for .02, there is no way im remounting that piece of crap, you think the problem would be fixed with a tial? all my friends LOVE them, anything else thats good aside from tial?
Re: (Schister66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 »</TD></TR><TR><TD CLASS="quote">Dont bother with the RS...get a Tial and forget about it. Its the ONLY bov i'd recommend for people over 300whp</TD></TR></TABLE>
cool, sorta the answer i was expecting
Re: (mike93eh2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike93eh2 »</TD></TR><TR><TD CLASS="quote">tial rules! anyone know where you can get their new 50mm ??</TD></TR></TABLE>
its not out yet
its not out yet
Re: (blinx9900)
its not out yet </TD></TR></TABLE>
it says release date is jan. 2nd ? i dont know...
http://tialsport.com/NewHotness.html
Re: (mike93eh2)
http://tialsport.com/NewHotness.html</TD></TR></TABLE>
trust me, its not out yet. i talked to tial about it yesterday, he said a few weeks...
Re: (boosstboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosstboy »</TD></TR><TR><TD CLASS="quote">wow, this is the first time i heard of this. i wonder how much more the new one will be.</TD></TR></TABLE>
im gonna take a stab in the dark and guess $30-40 more than the old one...
Re: (mike93eh2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike93eh2 »</TD></TR><TR><TD CLASS="quote">why would it be more? all they basically did was change the ports on it.. im pretty sure this new one will be taking the place of the old one.</TD></TR></TABLE>
cause there, new, they flow more, and there prettier, trust me, they will cost more.
http://www.hondaautomotivepart...84%29
1/3 way down the page, tial says it.
Re: (mike93eh2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike93eh2 »</TD></TR><TR><TD CLASS="quote">you might want to double check your link </TD></TR></TABLE>
woops here is the one i meant
https://honda-tech.com/zero...age=6
Re: (mike93eh2)
the way the parts have to be machined has changed
I ended up with a generic rs and with the stiff spring out it works quite well, holds boost up to 15psi and no surge. In the future when I go to a bigger turbo I will throw a tial in there but until then the rs design is working for me.
Come on people. Don't you think you're going a little bit overboard with the Tial bandwagon? Yes, they make great products, but it's not the only working BOV on the planet. 40mm isn't big enough? I think my Blitz is only 35mm, and it works great. If you're getting compressor surge, it's probably because your vacuum isn't strong enough.
