BOV flutter
Old Apr 7, 2005 | 09:05 AM
tegon-gsr's Avatar
Default BOV flutter
I have a greddy type s bov and before on my greddy kit it would sould normal and crisp. now that i changed my turbo set up its flutters alot. I changed the screw from soft to hard but still could not get it right. any one can help also would me changeing my turbo make a diffrence from a greddy to a garett.HIFi 60 like a sc/61.
Old Apr 7, 2005 | 09:12 AM
Slammd Sol's Avatar
Default Re: BOV flutter (tegon-gsr)
try a different/better vac source
Old Apr 7, 2005 | 09:23 AM
tegon-gsr's Avatar
Default Re: BOV flutter (Slammd Sol)
i try using the fpr for vac but i do have like 3 tee's on it people say use the brake booster but i dont have a fat tee that slims down to a small tee for my bov hose?
Old Apr 7, 2005 | 09:33 AM
tegon-gsr's Avatar
where else could i hook it up to other then the break booster? i have alot of tee's on for the boost controller,wastegate, Boost gauge and bov
Old Apr 7, 2005 | 09:49 AM
adictionbass's Avatar
you can use any line on the intake manifold. You can get a vac. manifold from golden eagle or the like if you wish.
Old Apr 7, 2005 | 09:56 AM
Drkaccrd's Avatar
I'm having the same problem but with HKS SSQ. I changed my inlet pipe size and intake and now it sounds gay...... I need help too.
Old Apr 7, 2005 | 10:00 AM
Doodoo's Avatar
Default Re: BOV flutter (Drkaccrd)
So how many psi are your guys running? You all describe what to me is normal operation.
Old Apr 7, 2005 | 10:01 AM
tegon-gsr's Avatar
Default Re: BOV flutter (Doodoo)
7 right now but im geting tuned for 10 everyday driving and 14 high
Old Apr 7, 2005 | 10:06 AM
Drkaccrd's Avatar
I running the greddy kit internal wg at 8psi. The normal HKS sound a high pitch woosh at heavier throttle and at light throttle a flutter. Except now Im getting a bubbley flutter sound at light throttle 1000rpm to 3000rpm. Its sounds so gay..................
Old Apr 7, 2005 | 11:03 AM
EJ1 wilcox's Avatar
My turbo XS RFL BOV flutters if I am at partial throttle and let off the gas slowly...
But if I let off the gas quickly the sound is really crisp...
Is the BOV fluttering when you let off the gas quickly and from WOT? If so, then I think there is a problem, maybe you are hearing compressor surge?
Old Apr 7, 2005 | 11:15 AM
Drkaccrd's Avatar
Default Re: BOV flutter (EJ1 wilcox)
Whats WOT? And how bad is compressor surge? Is it fixable? Teach me Im new to the turbo thing.
Old Apr 7, 2005 | 11:26 AM
trentepic's Avatar
i think it might be normal for bov's to flutter at lower boost levels, becuase part of how the bov works is the boost pressure itself pushing the valve open.... mine sounds like aflutter or a purr or some goofy bird ot low boost but at 16 psi it sound like a normal bov
-Toby
Old Apr 7, 2005 | 11:36 AM
jason190's Avatar
Default Re: BOV flutter (trentepic)
WOT=Wide open throttle. and compressor surge is when the air is going out the intake side of the turbo (backing up) It is fixable but You have to make sure you have a good vaccume source.
Old Apr 7, 2005 | 12:01 PM
Drkaccrd's Avatar
Default Re: BOV flutter (jason190)
Thanks for the insight. Umm if I am getting compressor surge check to see if the intake pipe has some sort of restriction, and try find another vacuum source for BOV? Right now its running from the back of the iintake manifold. That should be sufficient enough right?
Old Apr 7, 2005 | 03:09 PM
donkiman's Avatar
yes back of the intake manifold is fine
Old Apr 7, 2005 | 06:24 PM
Rufus523's Avatar
Default Re: BOV flutter (donkiman)
I think if you hook it up to the wrong vac fitting on the BOV itself (there are two on the Greddy S, one is for a recirculation something or another) it will flutter and sound like ****.
Old Apr 7, 2005 | 07:02 PM
tegon-gsr's Avatar
Default Re: BOV flutter (Rufus523)
no i think i hook it up right there are two but ports it goes on the upper one not the lower one.
2004es2
Mar 16, 2009 12:54 AM
TEG777
Sep 11, 2005 01:20 PM
bumsta217
Sep 29, 2003 04:01 PM
wickedxboi
May 21, 2003 08:33 PM
KLN
Jul 3, 2002 10:35 PM
