b18b1 map cel code 3 issues after volt tests
Old Apr 16, 2012 | 04:33 PM
mr2turbo007's Avatar
Default b18b1 map cel code 3 issues after volt tests
I have been struggling with a map sensor problem on my b18b1 ls in a 94 eg cx. The only code im throwing is 3 for the map sensor. I tested for volts at the sensor on all 3 wires got nothing according to the pgm-fi troubleshooting guide for map sensors.
I then tested the wires at the ecu per the trouble shooting code and got got approx. 4.5volts on d17 d19 d21 (should it be 3 volts??). The trouble shooting guide said to look for misconnections in the wires to the map sensor.
I found no wiring issues, so I wired the sensor directly from the ecu to the map sensor with some spare wire. It fixed the d19 to yellow with red sensor issues becuase it shows 5 volts.
When I test white (+) and green/white(-) i get no volts even with it being wired directly.
I have also tried 3 different map sensors and 3 ecu's ( two p75's and 1 stock p05).
I would be extremely thankful for any help this issue is driving me freakin crazy.
Old Apr 16, 2012 | 04:46 PM
Former User's Avatar
Default Re: b18b1 map cel code 3 issues after volt tests
Sounds like a bad ECU.
Old Apr 16, 2012 | 04:48 PM
damn so all 3 ecu are bad?
Old Apr 16, 2012 | 04:49 PM
Did you try all three ECUs after running three new MAP sensor wires?
Old Apr 16, 2012 | 05:01 PM
yea 2 p75's and one p05, and changed 3 map sensors, all with the same result with direct wiring
yellow/ red running directly to d19
green/white directly to d21
white directly to d17
When I test with a volt meter white (+) and green/white(-) even directly wired still nothing. I haven't wired anything permanent until I know it is fixed, they are just twisted
Yellow/ red (+) to a body ground gets 5 v.
I did not volt test all 3 ecu's but the one I did test got 4.5 not 3v at d17 d19 d21
The only other thing I know to try is the sensor plug itself, which I have another to try
Old Apr 17, 2012 | 06:29 AM
bump
Old Apr 23, 2012 | 06:22 PM
strikerage's Avatar
I get 3v white, 5v other. My white wire was separated at the ecu so map wasn't working. Could just be a wiring issue.
Is white supposed to be 3v or 5?
msinsky14
Nov 25, 2008 05:57 PM
92ehatch
16
Feb 19, 2007 11:41 PM
DarkBB4
May 8, 2005 09:01 PM
gokuson
Mar 18, 2003 07:27 PM
logistixz
Jun 20, 2002 01:06 PM
