95 integra ls, cel code 5, is it a map sensor problem?
Old Mar 17, 2003 | 12:18 AM
gokuson's Avatar
Default 95 integra ls, cel code 5, is it a map sensor problem?
i check the cel codes and got 5 fast flashes, looked around on the net and found out that it's the map sensor. I changed out the map sensor, replaced all the vacuum hoses, and reseted the ecu but still comes out to cel code 5. What else could cause the problem? thanks
Old Mar 17, 2003 | 06:08 AM
JimBlake's Avatar
Default Re: 95 integra ls, cel code 5, is it a map sensor problem? (gokuson)
Before changing the sensor, did you check to see if the sensor was bad? It could be bad wiring between the sensor & the ECU.
Old Mar 17, 2003 | 07:53 AM
dabrown's Avatar
Default Re: 95 integra ls, cel code 5, is it a map sensor problem? (JimBlake)
I had a code 3 and it turned out to be a wire was loose on the map sensor.
Old Mar 17, 2003 | 08:22 AM
gokuson's Avatar
Default Re: 95 integra ls, cel code 5, is it a map sensor problem? (dabrown)
how do i check if the connection is good? The connector has three wires going to it, I know how to use a multimeter. Which wires are ground and power? thanks
Old Mar 18, 2003 | 06:18 AM
JimBlake's Avatar
My '95 Integra Helm manual says code 3 is MAP sensor, code 5 doesn't exist. What's up with that?
All 3 wires for the MAP sensor go to the ECM. D17 on the ECM harness is Wht/Yel at the MAP sensor. D19 is Yel/Red (Yel/Wht for GS-R). D21 is Grn/Wht.
With the ignition on, check each outer terminal vs. the center one. Should be 5v in both cases. Otherwise, there's a fault tree but I'm too lazy to type it all here. Wouldn't hurt to get yourself a Helm manual.
Old Mar 18, 2003 | 01:20 PM
dabrown's Avatar
Are the blinks Long or Short or Both for your check engine light?>
Old Mar 18, 2003 | 07:27 PM
gokuson's Avatar
the blinks are very short. Less than a second, probably a milisecond. There's five blinks and it just repeats five blinks. tia
mr2turbo007
Apr 23, 2012 06:22 PM
jus_spooln_wicha
Jun 13, 2007 12:04 PM
JasonST
Apr 26, 2006 07:36 AM
DarkBB4
May 8, 2005 09:01 PM
chrysler kid
Sep 28, 2004 07:24 PM
