Turbo Question?
Okay, so im a little confused on the wastegate.. If I were to run 14lbs of boost I need a 14lb spring correct? But if I have a 14lb spring and i wanted to crank the boost up to 20psi how would that work with a 14lb spring?
9deuce9rr
Mar 28, 2004 12:32 PM
