Brake swap Q's
Old Apr 1, 2012 | 01:51 PM
98CoupeE's Avatar
Default Brake swap Q's
hello, im planning out my build and trying to figure out which way to go with brakes. ive been going through the brake swap section in the teq answers and many other threads to try and figure this out. ive got a 00 civic cx. i want to go 4x114 because i wont have to buy different rims. i found a store near me selling a 4x114 itr conversion. id like to know:
if id need to get 36mm hub axles or is it still 32mm?
what year were itrs made with 4x114 pattern/what country?
do i need to use the integra upper control arm?
will i have to change my prop valve?
what master cylinders would i need?
is this trailing arm the same as my civic?
if anyone has any answers to these questions it would be much appreciated, thanks alot.
Old Apr 1, 2012 | 02:07 PM
civicjunkie17's Avatar
Default Re: Brake swap Q's
if id need to get 36mm hub axles or is it still 32mm? 32mm
what year were itrs made with 4x114 pattern/what country? 96 spec
do i need to use the integra upper control arm? Not sure.
will i have to change my prop valve? You should for them to work to their full potential.
what master cylinders would i need?I would go with 99-00 si
is this trailing arm the same as my civic?yes
Old Apr 1, 2012 | 02:25 PM
98civdx's Avatar
Master Detailer
if id need to get 36mm hub axles or is it still 32mm? They are 32mm, only the 97+ JDM ITR got 36mm outers.
do i need to use the integra upper control arm? No, you cannot use the Integra UCA. You must keep the stock peice.
will i have to change my prop valve? No, keep the stock one.
what master cylinders would i need? Go with the MC for the front calipers you have. So the DC 15/16 will work.
is this trailing arm the same as my civic? In a sense, yes they are the same. They will bolt exactly the same as the old arm.
Old Apr 1, 2012 | 07:42 PM
98CoupeE's Avatar
thanks alot for the info
Old Apr 1, 2012 | 07:57 PM
98CoupeE's Avatar
would either of you happen to know if my existing brake lines will connect right to the new calipers or will i need new connections
Old Apr 1, 2012 | 08:02 PM
98civdx's Avatar
Master Detailer
Do you have rear drum? if so, you will need to switch the rear lines. however, I think the fronts will work fine.
Old Apr 1, 2012 | 08:32 PM
98CoupeE's Avatar
yes its rear drums and would i use a 96 itr line?
Old Apr 1, 2012 | 08:37 PM
98civdx's Avatar
Master Detailer
Yes, if you can get them with the conversion, if not, regular ole Integra lines will do.
Old Apr 2, 2012 | 07:36 AM
98CoupeE's Avatar
awesome thank you
Kannan08
11
May 4, 2012 08:01 AM
gwegcivic
Mar 14, 2012 07:25 PM
JR CIVIC
13
Aug 28, 2010 06:15 AM
Pr0ject93hb
Dec 17, 2006 11:52 AM
