Help diagnose Tranny fluid leak...(picture included)
Old Mar 31, 2012 | 01:21 PM
-iLLuZioN-B18C1's Avatar
Default Help diagnose Tranny fluid leak...(picture included)
I have leaks that seem to gather along the red dotted line. Is this just a new seal? I can't seem to find the part number on majestic honda.
Old Mar 31, 2012 | 01:26 PM
JDM_teh_WIN!!'s Avatar
Default Re: Help diagnose Tranny fluid leak...(picture included)
It's not a "seal" you can buy. You need to use Hondabond or some type of liquid gasket. Best way to repair that would be to crack it open, clean the mating surfaces, apply hondabond and close it up.
Old Mar 31, 2012 | 01:28 PM
I was just doing some reading. Would it also be possible for it to be the rear main seal dripping its way down to this point?
Old Mar 31, 2012 | 01:42 PM
No.
Old Mar 31, 2012 | 04:19 PM
No.
before I go and rip that apart, could it be possible it be anything else? Maybe something else to look for around the area?
Old Mar 31, 2012 | 04:29 PM
Former User's Avatar
What car and engine?
Rule out an engine oil leak, such as from common places like the oil pan gasket or at the top of the engine (distributor, VTEC solenoid, valve cover).
You can add a leak detecting dye to the MTF. If the dye does not appear in the leaking fluid, then the leak is likely engine oil.
Old Mar 31, 2012 | 09:34 PM
Yeah, I guess I should have clarified my answer. Make sure you know what it's leaking. Engine oil or transmission fluid. Transmission fluid will not leak out of the rear main seal.
Old Apr 2, 2012 | 09:25 PM
afrikainside's Avatar
Once again I agree with RonJ only thing I would add to what he said it clean up the general area before you add that dye.
93DA9
Aug 28, 2008 02:25 PM
futurefastguy
Aug 23, 2007 12:09 PM
andyxle
11
Aug 16, 2007 10:40 PM
EG2Driver
Nov 1, 2006 07:23 PM
JapJunkie
May 10, 2004 12:31 PM
