D15b7 Low idle
Re: D15b7 Low idle
Agree with above. How low is "low"? I mean, the warmed up idle speed is already pretty low (mind hovers at about 500rpm when it's all warmed up) so I'd say you must be really close to stalling....
Re: D15b7 Low idle
Well the thing is, it's automatic and when I put in drive after warmed up, it seems to idle lower than usual. Plus I dont have a mph on my cluster so I can't tell. But I know it's lower than usual.
Re: D15b7 Low idle
You mean you don't have a tachometer? (RPM)
The idle is supposed to drop when the car is warmed up. The only reason the idle is high is to warm up the engine. You'll notice that your car shifts at a higher RPM when it's cold. This also helps warm up the engine. When the engine is warm the RPMs drop automatically. But if it feels and sounds like it's about to die, then there may be something out of adjustment.
Re: D15b7 Low idle
Yes! I have no tach!!!
That's why I can't give you a number
And yes I know how it works to warm up and stuff.
But I know my car and all I wanted to know is what kind of "adjustments would it probably need?
I know its idling low.
Re: D15b7 Low idle
Without a tach, it's going to be really hard to diagnose since you don't have something measuring the engine speed. Do you have a shop manual? Try the troubleshoot section in it.
BTW, what kind of car is this? No tach and automagic tranny means a CX, I assume? Just a guess...
Re: D15b7 Low idle
Well first off, you don't need a CEL code most of the time to tell you theirs a problem.
for example, like a blown head or a vacume leak. Or when the timing is off.
Re: D15b7 Low idle
Maybe I picked the wrong word then.... I think what I meant to say was "hard to test" since you don't have a tach to check and make sure the engine speed is correct to spec.
Re: D15b7 Low idle
By tune up I did
Spark plugs/wire
Oil/intake filters
Which was done about 18k miles ago and I always do my oil changes every 3k
Is their anything else I missed on my tune up?
Spark plugs/wire
Oil/intake filters
Re: D15b7 Low idle
Oh yes and I did the fuel filter also
But the cap and rotor no.
Maybe when I do that I'll go and check the timing as well.
Should I buy a tach from auto zone or any place to help me with the rpm?
And if I do would it hook up to the car even though it originally didn't have one ??
Re: D15b7 Low idle
Cap and rotor might do it.... But I think timing issues would cause a misfire or something. If the tach is just for the fix, don't waste your money. If you do get one, it should hook up to the car. You might have to look at some diagrams and wire some stuff, but it should work.
Re: D15b7 Low idle
My set up!
What do you think? Just to know if this is cool to run.
Obd1 pr4 ecu , hush22 hydro kit, hasport motor mounts, sway bars as well as coil overs
Ok I got a high cr b20b with gsr and cat
2.5 rsr exhaust with resonator
Aem intake and a b18a1 intake manifold & tb
Jdm ls tranny with p30 flywheel and a stage 1 clutch
wuggiewuggie
09-22-2007 08:09 AM
