tranny is leaing fluid
Old 08-19-2007, 04:49 PM
futurefastguy's Avatar
Default tranny is leaing fluid
Ive noticed that my tranny is leaking fluid but i don't know from where. is there a common place where the tranny will leak fluid from? the tranny has 160k miles on it btw. thanks in advance.
edit: i kno i messed up the title
Old 08-19-2007, 05:39 PM
egsleepercivic's Avatar
clean the engine off real good and wait for to start leaking agian, maybe you have a bad axle seal, you need to narrow it down a little better
Old 08-19-2007, 05:40 PM
crazyguy's Avatar
Default Re: tranny is leaing fluid (futurefastguy)
i think it might be your rear main seal.cause there is no seal or gasket for the tranny.to replace the rear main seal is a pain in the butt .time consuming.if u plan to do this by yourself then i will give u an idea of how to do it
Old 08-23-2007, 11:33 AM
Default Re: tranny is leaing fluid (crazyguy)
thanx for the replies. im gonna clean up my bay really good and see where its coming from.
Old 08-23-2007, 11:37 AM
b20beast978's Avatar
jack up your car front the front and look right under where the flywheel is....if your leaking oil out of there its your rear main seal and that needs to be replaced asap since it leaks like crazy!
Old 08-23-2007, 11:55 AM
chingpo05's Avatar
not always <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyguy &raquo;</TD></TR><TR><TD CLASS="quote">i think it might be your rear main seal.cause there is no seal or gasket for the tranny.to replace the rear main seal is a pain in the butt .time consuming.if u plan to do this by yourself then i will give u an idea of how to do it</TD></TR></TABLE>
it could be his axle seals the rear main seal would leak oil not tranny fluid
Old 08-23-2007, 12:09 PM
instructor74's Avatar
There is a seal for the input shaft but the only way to get to it is to pull the entire trans apart, you have 2 drive shaft seals, if its a linkage shifter there is a seal under the rubber dust boot. There is a crush washer for the drain plug and lets not forget about it could be leaking from around the case half. there are 1 or 2 others but there are the most common ones
jdmstyleEJ6
12
04-02-2010 08:07 PM
93DA9
08-28-2008 02:25 PM
invisible
03-11-2007 09:35 PM
Themouse
11-22-2006 05:10 PM
Discontained
22
10-16-2006 02:07 AM
Quick Reply: tranny is leaing fluid
