90 degree fitting directly off the turbo
Any issue with this?
my turbo sits EXTREMELY low so this is the only way i can get the SLIGHTEST bit of downward flow on the return line
http://ts1.mm.bing.net/images/thumbn...dfd0857a4bbd88 This Directly off the turbo then the line will have a SLIGHT decline ...anything else hangs to low and will cause my return line to hang lower then the fitting on the pan.
FML...not enough room for something like that...i hate my ****ing setup
Im about to run down to the garage and take a picture so you guys can see what im dealing with and maybe give me some ideas
Heres the best picture i have it just shows how low my turbo sits
last year i was ran the center section straight up and down. with a 45 right off the flange and then another 45 AN fitting and there was literally 1-2mm of AN line in between the the oil pan AN fitting and the turbo AN fitting but it had a VERY slight upward angle on the line im talking not even 1/4 inch
This year i had to take the setup off to fix something so this time i clocked it a little bit thinking it would help get some leverage on the return line. so i then got a straight fitting off the flange to a 90 degree AN fitting fitting and it still hangs to low.
Thats why i was thinking of going with a 90 degree BARB style fitting because it should be smaller..even tho the center section is clocked i still cant use the 90 degree barb fitting?
End point of the fitting hangs below the fitting on the pan...The fittings are pretty big
Maybe a barb fitting will be smaller. Im going to try a brass barb 45 tomorrow
That picture does not do justice on how low my turbo sits.
Let me guess Miny Ram? Yeah i have the same issue i use a prebent rubber heater hose and some hose clamps. Ugly and cheap but it works.
Ignitecivic
Feb 6, 2005 08:33 PM
