Turbo Return line questions
Old Dec 20, 2007 | 11:14 PM
nabin's Avatar
Default Turbo Return line questions
im having trouble gettitng my return line hooked up on my turbo kit. im using a return line with -10 AN fittings (the fastturbo.com setup). I have a tubular style manifold and an sc61 with the s housing. Due to the size of the comp housing, i cannot turn the fitting that mounts to the turbo a full 180 degrees, so the use of that minimal. i have two 45 degree fittings on the return line right now. one from the fitting that mounts to the turbo and one from the oil pan. It causes a slight kink in the line....not so much that it would completely cut off flow, but enough that you can tell its not straight. So my question is how much of a "kink" is too much to affect the use/performance of the turbo?? Also, is it possible to use a 90 degree fitting off of my turbo? I heard that there could be no flat spots, would a 90 cause a flat spot?
pictures to come sometime soon...
Old Dec 21, 2007 | 03:16 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Turbo Return line questions (nabin)
can you put a straight -10 fitting on the turbo and put a 90* 45* 135* hose end on it?
Lewy. Dee Ayy
May 15, 2012 06:03 PM
Lewy. Dee Ayy
Mar 28, 2012 04:33 AM
BigZeke5
Oct 16, 2008 06:20 AM
GReddy SI
Aug 29, 2004 09:20 AM
racerxadam
Apr 25, 2002 10:28 PM
