[Help] Horn problem after wiring car alarm to the stock horn
Old Mar 25, 2012 | 06:39 PM
uhhRay's Avatar
Default [Help] Horn problem after wiring car alarm to the stock horn
Hey Honda-Tech, I have a 94 Civic EX Coupe,
Earlier I was wiring my car alarm to the stock horn.
I wired the brown(Horn output) wire straight to the blue/red wire.
It works, but it was REALLY quiet. Then after a few more times using it, it stopped working. The horn still works if you manually press on it using the steering wheel, but not with the alarm remotes.
Any ideas?
Did I blow a fuse?
Did I use the wrong wire?
Do I need a relay?
Old Mar 25, 2012 | 08:24 PM
uhhRay's Avatar
Default Re: [Help] Horn problem after wiring car alarm to the stock horn
bump, help!
Old Mar 25, 2012 | 09:54 PM
Alpha Q's Avatar
I'm guessing the alarm does not give enough power to the horn.
Wire it to the horn wire in the steering wheel.
Old Mar 26, 2012 | 06:53 PM
uhhRay's Avatar
Okay thanks, I'll try that.
Old Mar 26, 2012 | 09:04 PM
delsolo95's Avatar
the horn output isnt giving enough juice or the connection to the blu/red horn wire is not good. i just finished my viper 5704 alarm and the horn output is wired directly to the blu/red, whatever the case is you might need a relay. get a 5 prong spdt relay at your auto store and wire as shown
relay diagram
30 to chassis ground
87 to vehicle horn wire
85 to constant 12v(+)
86 to alarm horn output (-)
silversilver
11
Feb 13, 2016 07:36 PM
chillerice
Audio / Security / Video
Apr 30, 2013 07:54 PM
ej888
Apr 11, 2011 09:10 PM
MantisX
Aug 27, 2009 03:44 PM
ayos ctr_hatch
Dec 23, 2008 11:52 PM
