Horn wiring
Horn wiring
I searched but only came up with people looking for aftermarket steering wheel horn wiring.
its for an EG
I'm trying to wire up an alarm and the alarm ask for a wire to hook it up to the horn(doesnt come with its own siren)
I found this: 92-95 the wht/grn is power and blu/red is ground
I have no idea with what wire to hook up the alarm to. Don't know what wire is always hot and i don't want to hook it up to that wire and have a fire, i also don't want to ground it for obvious reasons
Basicly, the alarm would throw out a current to activate the car horn, what wire do i cut into to get this effect?
its for an EG
Re: Horn wiring
You didn't specify your car information as required with all tech threads, especially in this section.
I'm assuming you are still talking about your 94 Hatchback.
Does it have SRS (airbags) and just to know specifically which setup you have, does it have a passenger airbag in the dash (don't think it would as it's a DX or less).
SRS changes the wring diagram a little bit.
Re: Horn wiring
I actually do have SRS on the steering wheel and i do have a passenger airbag.
The srs on the steering wheel appears to be cut as i found the clockspring in the trunk and while doing some wiring i saw the wide thin wire that would have been connected to it also cut
edit: it is also giving me a SRS light, pretty annoying but i want to go aftermarket with steeringwheels in the near future
Re: Horn wiring
Before proceeding, under the steering wheel there is a small access door with 1 single screw (assuming the steering wheel is still stock)....
Open that access door and make sure the red cap is on the airbag harness. If it's not shorted out (with the red cap), you are running the risk of accidental airbag deployment.
I'll get you the wiring diagram in a moment.
You have the same sort of red cap setup for the passenger airbag too. The access panel on the passenger side is help on with two screws and you have to drop the glove box first before you can spy the panel.
Okay the difference between SRS and not SRS with the horn is a Horn Relay. You have one, without SRS does not have one. The other thing you should know and can be seen with the diagram, power goes from the battery to the horn and the switch (and relay) basically ground out the horn to activate it.
Re: Horn wiring
Ill check up on the red cap tomorrow, what exactly does it do?
Re: Horn wiring
Your diagrams are above, I edited my post to add them.
A little blurry but not horribly so unless yer on a phone with a tiny screen, then it might be a bit much.
Re: Horn wiring
It's shorts out the air bag connector which prevent accidental discharge. Even a static discharge can set off the airbag from what I understand.
I appreciate your assistance
Re: Horn wiring
The horn circuit wiring is that the Wht/Grn wire is always Hot (has power (+)).
To trigger the horn, ground (-) is applied to the horn. Generally, the wire from the alarm could be hooked up to either the Blu/Red wire going to the horn or the Blu/Grn wire going to the horn relay. Applying ground to either the Blu/Red or Blu/Grn will sound the horn.
Re: Horn wiring
Havent looked at the diagram in detail yet, just a quick skim
Re: Horn wiring
The way the horn circuit is on the 94 Civic, you can't hook up another 12 volt source to any of those horn wires to trigger the horn.
Re: Horn wiring
It was made to work with a siren( it would send the 12v to that) and the siren would be grounded thus sounding it. Since I have no siren I was just curious if I could hook it up to the stock horn somehow
Re: Horn wiring
Either get a cheap siren, or go to the junk yard and pull a civic horn to be your siren. You can wire the second horn to operate as grounded and you are applying the 12V from the alarm.
uhhRay
03-26-2012 09:04 PM
phathodna35456
Audio / Security / Video
05-16-2003 04:47 AM
