viper 5900 horn problem
Old Dec 22, 2008 | 04:48 PM
ayos ctr_hatch's Avatar
Default viper 5900 horn problem
I 95 integra with viper 5900 with back up battery and tilt sensor. I hooked up a relay to the horn alarm wire to pole 85, ground to 87, 12 volts 86 horn wire to 30. I tested before I put everything back together and worked properly. Now my problem is when my alarm is trigered horn stays on even when I disarm it. Horn wire is also hooked up to my momo steering wheel I checked to see if the horn button is stuck and its not. When I started the car and put the horn fuse back in it was not going off, but when I pressed the horn button it got stuck on again. I wonder if the problem is even with alarm?
Old Dec 22, 2008 | 05:20 PM
Default Re: viper 5900 horn problem
Ok, when I unhooked the horn wire from the steering wheel it works properly. When I hook it back up and triger the alarm it stays on. I just need to know what I need to do to make the horn work properly when hooked up to the steering wheel
Old Dec 23, 2008 | 12:38 AM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Sounds like a bad relay. Were did you tag the horn wire at?
Old Dec 23, 2008 | 06:38 AM
at the srs harness
Old Dec 23, 2008 | 07:00 AM
Try it at the dash harness. Also swapp out the relay. Use a bosh or other good relay
Old Dec 23, 2008 | 07:57 PM
wheres a good place to buy bosch relays
Old Dec 23, 2008 | 11:52 PM
Pepboys, auto zone, fry's. Try your local electronic store. If not I'll send you one.
Jon Petersen
Oct 2, 2017 03:07 AM
uhhRay
Mar 26, 2012 09:04 PM
MantisX
Audio / Security / Video
Aug 27, 2009 03:44 PM
phathodna35456
May 16, 2003 04:47 AM
