OBD1 or OBD2 ?
Old Mar 25, 2012 | 12:42 PM
UltimateAmature's Avatar
Default OBD1 or OBD2 ?
so i have a 98 civic hatch, i have the stock harness, im building a mini-me..
i bought a y8 head for the y7 block i have, so i did that swap, the guy i got the head off said that the distributer was obd2. which is what i thought i needed. so i swapped the heads and such i got to looking at the plugs for stuff because i never did a swap before, so i started matching some up and i do have most tagged, when i looked at the distributer plug it was different from he one on my harness ? does anyone have a link that shows what plug is which ? like pictures of the obd1 or 2 plugs. i have ran into a wall and am trying to find a way around it. Any info will help im sure. thanks
Old Mar 25, 2012 | 12:44 PM
Dc4LsTeG's Avatar
EK9
Default Re: OBD1 or OBD2 ?
Why don't you just post a pic of your two plugs
Old Mar 25, 2012 | 12:55 PM
in the works of gettin my computer fixed. im at a friends hoping i can find out what i have, i dont have pictures and like i said i cant find straight on pics on the internet.
Old Mar 25, 2012 | 01:06 PM
i do know that the old distributor on the y7 head had 8 wires coming from the plug and the y8 distributor has 9 if that helps..
the plug on my harness
Old Mar 25, 2012 | 02:11 PM
the distributor plug
Old Mar 25, 2012 | 03:01 PM
any ideas of which is obd1 and whats obd2 ?
Old Mar 25, 2012 | 03:13 PM
94EG8's Avatar
Seagull Management
They're both OBD2
The first pic is an OBD2A plug ('96 - '98 Civic)
The second pic is an OBD2B plug. ('99 - '00 Civic, except Si/HX)
Y7 and Y8 distributors are identical between the same years/OBD level. If you have your old Y7 distributor simply reuse that.
Old Mar 25, 2012 | 03:31 PM
i have the distributor off the 98 y7 .. so this will work ?!
if so, this saves me so much time.
Old Mar 25, 2012 | 03:55 PM
HondaPartsHero's Avatar
Technical Hero
Yes
Old Mar 25, 2012 | 03:59 PM
decenttttt. thank you both
Austin_22
Mar 24, 2014 08:06 PM
stevieturbos
May 6, 2010 07:13 PM
melissashelton1
Dec 21, 2009 12:28 PM
foowitdaredek
11
Jul 23, 2007 11:30 PM
willyboyK20
14
Jun 17, 2007 06:32 PM
