Dizzy questions
Dizzy questions
I have a z6 head on y8 block. I have the y8 dizzy on there now holding with 1 bolt I need to make it right. If I get a z6 dizzy it a obd1 I need obd2 is there and easy way to do this or do I need wire harness.
Re: Dizzy questions
You could go to a junkyard, get the 2 plugs from the harness side of an OBD1 Honda/Acura, and get the plug from an OBD2 distributor (OBD2A or OBD2B depending on which one you're dealing with). Then you could make your own conversion harness, instead of hacking up your stock engine harness or distributor plugs. There's a link to a comparison of the OBD1, OBD2A, and OBD2B distributor wiring in my signature; at the bottom of my post. Match up the wires by pin placement, not by the color of the wires, because Honda used all sorts of different colors throughout the years.
DelSlowmo
03-13-2010 12:54 AM
IDriveHonda
07-08-2003 07:03 PM
