rebuilt motor not starting
Old Mar 23, 2012 | 09:12 PM
kiamra's Avatar
Icon6 rebuilt motor not starting
I have a motor I recently rebuilt from a junk yard, installed it and now I cant get it to start. I can get the motor to crank over but it won't start. I checked alll my grounds, I'm getting fuel and spark. I also changed out the ecu and main relay and tried a differnt distrubitor. Im kinda stuck, any options would nice
Old Mar 23, 2012 | 09:19 PM
famous323's Avatar
Default Re: rebuilt motor not starting
mechanical timing set right
Old Mar 23, 2012 | 11:42 PM
Dc4LsTeG's Avatar
EK9
X2 on mechanical timing. Do you have the firing order corect? Any cels?
Old Mar 24, 2012 | 04:00 AM
kiamra's Avatar
Yeh timings right on no cel, and firing order was checked a few times. Ive seen a few other threads where people have the same problem and cant figure it out. I think i might change my internals on the dizzy. Ive also checked compression while cold since it wont start had 90 across all cylinders , seemed low so i added a cap of oil then got 120 on all. Thanks for the replys so far.
Old Mar 24, 2012 | 04:38 AM
grumblemarc's Avatar
The Grumpiest
A healthy engine at minimum runs 135.
Old Mar 24, 2012 | 07:36 AM
famous323's Avatar
did you properly tension the belt? too much slack= cranking but no start! and if its not to much post a video.
Old Mar 24, 2012 | 07:52 AM
dategb16vortech's Avatar
Double check all grounds are tight and have a good metal contact surface especially the one by the starter. Sandpaper is a must to ensure the grounds have good contact
Old Mar 24, 2012 | 08:08 AM
98civdx's Avatar
Master Detailer
what engine, what car? etc.....
Is it just cranking, is trying to start?
Is this is a b series 90psi is very low, and the fact it went to 120 with oil says the motor you bought is ****.
Old Mar 24, 2012 | 09:09 AM
The Grumpiest
Even if it was a D-series that compression is entirely too low. I thought it was rebuilt?
Old Mar 24, 2012 | 09:20 AM
famous323's Avatar
x2 on the rebuilt part
Old Mar 24, 2012 | 09:27 AM
Dc4LsTeG's Avatar
EK9
This. It must not of been rebuilt correctly
Old Mar 24, 2012 | 10:03 AM
famous323's Avatar
did you gap the rings to spec? clock the rings right? heck did you hone out your bores and check for any out of round issues? might be excessive blow by getting oil on the plugs thus getting no spark. we need more details was this home done, sent out to a reputable shop, the posts just don't add up.
BigMac28
37
Jan 16, 2019 02:02 PM
eesupra420
13
Aug 11, 2011 07:12 PM
lt1guy
Feb 14, 2010 07:06 PM
Spody02
12
Sep 9, 2008 10:16 AM
wannab20hatch
13
Dec 3, 2003 04:22 AM
