gsr pistons in a ls block?
Old Oct 10, 2002 | 03:55 PM
ls_vtec_b18a1's Avatar
Default gsr pistons in a ls block?
i got a ls vtec that i want to put gsr piston in. what i need to know is what compression i will have and do i use the ls rods? do i need a thicker head gasket and is this a good set up.
Old Oct 10, 2002 | 05:44 PM
non-VTEC's Avatar
Default Re: gsr pistons in a ls block? (ls_vtec_b18a1)
dont bother with GS-R pistons...........the compression ratio wont be high enough to justify the cost of parts and labour............get a set of B16 pistons and you will be happy............
Old Oct 10, 2002 | 05:58 PM
Default Re: gsr pistons in a ls block? (non-VTEC)
if i run turbo would they be good and a zex kit also.
Old Oct 10, 2002 | 06:09 PM
non-VTEC's Avatar
if your gonna run turbo and nitrous then you will deffinatly not want any stock honda cast pistons........your gonna have to get low compression forged aluminium pistons (JE, Weisco, SRP) and strong connecting rods (eagle, crower, carillo) to take the abuse............get ready to dish out lots of $$$ to make it all work togeather without blowing **** up........
[Modified by non-VTEC, 10:21 PM 10/10/2002]
Old Oct 10, 2002 | 06:15 PM
3rdGteg's Avatar
if your gonna run turbo and nitrous then you will deffinatly not want any stock hinda cast pistons........your gonna have to get low compression forged aluminium pistons (JE, Weisco, SRP) and strong connecting rods (eagle, crower, carillo) to take the abuse............get ready to dish out lots of $$$ to make it all work togeather without blowing **** up........
Old Oct 10, 2002 | 08:35 PM
lazy bum shaughn's Avatar
You can use your stock internals if you're going to keep your boost level low. Then upgrade when you're going to raise the boost.
young geezer
Oct 12, 2010 08:20 PM
bakomack
Jul 18, 2010 10:46 PM
tealsvteceg
Feb 14, 2008 06:03 PM
blueskiesfade609
Nov 14, 2003 12:09 PM
sadcivic
Sep 25, 2003 08:00 AM
