B&M Short Shifter Questions
Old Mar 8, 2012 | 03:12 PM
MIEj1's Avatar
Default B&M Short Shifter Questions
Hey guys, so I'm in the process of installing my B&M short shifter.
I'm at the point where I have to install the shifter back to the shift linkage. The thing is, is I don't have the pin that goes in the whole where the linkage connects to.
What exactly do I need to order? Or does B&M not need some specific items. On the provided website, what parts could you tell me I need? Thanks.
I also have a pin from the front bushing that I'm replacing with energy bushings, am I able to use that pin? It seems to fit perfectly.
http://www.hondaautomotiveparts.com/...y5=SHIFT+LEVER
Old Mar 8, 2012 | 03:21 PM
MIEj1's Avatar
Default Re: B&M Short Shifter Questions
Plus I'm following this website. Give me some help!
http://importnut.net/shifter.htm
Old Mar 8, 2012 | 03:32 PM
94EG8's Avatar
Seagull Management
Use the sleeve from the original shifter or buy a new one from Honda. No you can't use that sleeve that's pictured.
Old Mar 8, 2012 | 03:41 PM
MIEj1's Avatar
Okay thanks. So that's all I'll need is that sleeve/pin? I currently have a ebay short shifter that uses those bearings, but it doesn't need a sleeve.
Old Mar 8, 2012 | 03:57 PM
94EG8's Avatar
Seagull Management
You'll need the sleeve, the 4 O-rings that go with it (the sleeve has 4 grooves) You may or may not need the factory bushings, I really can't tell.
Old Mar 8, 2012 | 05:02 PM
MIEj1's Avatar
Good thing my buddy had one of those sleeves with the o-rings! Thank god.
skratchyy93eg
Transmission & Drivetrain
Mar 4, 2016 05:37 AM
bonylad
Sep 15, 2005 05:08 PM
gameknb
Jun 11, 2005 07:32 AM
tweekerz
Jan 19, 2005 01:04 PM
ArchAngel Sabastian
Feb 2, 2002 12:09 PM
