Short Throw Shift.
Old Feb 1, 2002 | 04:20 PM
ArchAngel Sabastian's Avatar
New User
Default Short Throw Shift.
Do they make a short shift for us? or is it just bushings? and if so who makes that and has anyone rigged up anything that works nice.
thnx all
drinks on me.
Old Feb 1, 2002 | 04:28 PM
SOHCArchangel's Avatar
Default Re: Short Throw Shift. (Sabastian)
its just an adapter, B&m, dc sport, neuspeed, and i think a few others as well
Old Feb 1, 2002 | 05:45 PM
4doorH22's Avatar
Default Re: Short Throw Shift. (SOHCkordVTEC)
I don't have a short shifter. I'm thinking about cutting a bit off of my shift lever. Has anyone done this? I don't need shorter throws, the shifter just feels too tall for me.
Old Feb 1, 2002 | 06:10 PM
Nick M's Avatar
Default Re: Short Throw Shift. (4doorH22)
A friend of mine did it on his EG civic, he cut the shifter and rewelded it, so like u said, it sat lower.
Old Feb 1, 2002 | 09:31 PM
phatridinDus10's Avatar
Default Re: Short Throw Shift. (Hondasport94)
I have been debating doing that myself. I was just going to get it welded back. I heard that if your shifter is hollow not to do it. I can't tell that mine is, it feels pretty solid. I am about to install a short throw shifter, but I would like the shifter to be a little shorter as well.
Old Feb 1, 2002 | 11:12 PM
FastechAccord's Avatar
I have a B&M short shifter on my 97 and I also cut the shift down and rethreaded it. This made a huge difference from stock. The stock shifter is long enough to be put in a diesel truck.
Old Feb 2, 2002 | 12:30 AM
Bklyn TSi's Avatar
Banned
Default Re: Short Throw Shift. (EvoAccord)
I also got a b&m installed.. looking to shorten the shifter now... is it better to cut it down then reweld, or cut it and rethread? where can I get these done btw?
Old Feb 2, 2002 | 07:30 AM
Default Re: Short Throw Shift. (Stony TSi)
oh yeah i forgot C's japan makes the entire assembly 300 bucks and you would have to go through http://www.takakaira.com to get it
Old Feb 2, 2002 | 08:53 AM
urbanlegend21's Avatar
New User
Dave- have you removed the bushings in the plate for the shifter? that will drop the lever pretty good and might be what you are looking for
it will also stiffen up the throws
Old Feb 2, 2002 | 10:09 AM
Default Re: Short Throw Shift. (urbanlegend21)
no not really, it doesnt change the geometry of the shift, and unless you use metal washers or poly bushings it will be just as mushy
Old Feb 2, 2002 | 11:17 AM
scrubachu's Avatar
i have contemplated a short shifter adapter, but i have heard many horror stories about cutting and welding. im also a bit concerned about the change in shifting length. my brother had one on his 94 civic, and now the gears in the tranny are getting fu@@ed because the sort shifter forces the tranny into gear before it is actually ready. on top of that, the lude tranny is notorious for bad 3rd and 5th gear synchros. so, if you put a short shifter in, and then you force the tranny into gear before the synchros can line up, it would grind the tranny into gear. just a few concerns of mine. if anyone knows anything else about this, i would love to have some info.
Old Feb 2, 2002 | 12:09 PM
4doorH22's Avatar
Well, I don't want to change the "feel" of the shifting action (I like the way it feels already), I just want to shorten the lever.
Oh, and since I have a non-threaded Momo ****, no welding would be required as the **** just mounts over the top of the lever and is securred with alan screws.
ProjectCD5
Feb 21, 2006 11:55 PM
starbury
Feb 15, 2005 09:58 AM
IntegraBoy04
Aug 13, 2003 12:40 AM
Modifiyem
Jul 31, 2003 06:30 AM
Ekco
Jun 13, 2002 12:36 PM
