No fuel getting to cylinder #3
Old Mar 7, 2012 | 08:09 AM
VX2KO's Avatar
Default No fuel getting to cylinder #3
I have a stock 95 civic EX, and its been running like complete crap. Bad mpg, crappy idle and no power on acceleration. I pulled the spark plug in cylinder #3 and it doesnt smell like gas and has a black tip. the injector is engaging because I can hear it clicking. Does this mean its clogged or is something else wrong with the cylinder?
Old Mar 7, 2012 | 08:16 AM
NVturbo's Avatar
O.G. triple O.G.
Default Re: No fuel getting to cylinder #3
spark plug wires....on #3. Switch it out with #4 and see if the problem moves from one cylinder to the other.
Old Mar 7, 2012 | 08:36 AM
VX2KO's Avatar
I cant switch the wires. Each wire is just the right length to reach each cylinder.
Old Mar 7, 2012 | 10:01 AM
Former User's Avatar
Does cyl #3 have bright white spark?
Switch the injectors. Does the problem follow the injector?
Old Mar 7, 2012 | 11:49 AM
NVturbo's Avatar
O.G. triple O.G.
get new plug wires. problem solved.
Old Mar 7, 2012 | 02:49 PM
vitamin_c95's Avatar
or make sure the connecter didnt slide up inside the wire. I had one come like that from the factory. Or even make sure its a good connection period
Old Mar 7, 2012 | 03:16 PM
dumafit's Avatar
if you're not getting fuel to the cylinder, why does the spark plug wire matter? unless you're wording it wrong
Old Mar 7, 2012 | 03:25 PM
opps...somebody mentioned plugs wires and I lost track. My bad
Try swapping injectors around and see if it moves.
Wisdom Teeth
Mar 25, 2013 10:26 AM
BoostR41
Engine Management and Tuning
Jul 18, 2009 06:28 PM
jvillagran2000
15
Dec 2, 2008 02:03 PM
Brooklyn101
Oct 30, 2006 11:55 AM
project142
Jan 28, 2004 06:06 PM
