fan not turning on after dual core rad. install
Old Mar 5, 2012 | 01:43 PM
jonesEK's Avatar
Default fan not turning on after dual core rad. install
what up fellas.... I got a dual core and a slim fan... I kept the oem fan on but it wouldnt turn on someone told me to put the slim fan on... I did fan still doesnt turn on..
THE CAR DOES NOT OVER HEAT or get warm just stays in the middle...
I was thinking if i got a racing thermostat maybe that would make the fan turn on.
Any positive comments help out..
I know since it doesnt overheat its not a big deal.
Old Mar 5, 2012 | 02:20 PM
hannslebo's Avatar
Default Re: fan not turning on after dual core rad. install
Have you tried jumping the fan harness with a paper clip?
Old Mar 5, 2012 | 02:34 PM
Mashimaro's Avatar
are you trying to bleed the system?
if so, how long are you idling the car for? it may take over 30mins for the fan to turn on.
also, check your fuses just incase (i believe there is one for the fan in the engine bay fuse box by the battery).
Old Mar 5, 2012 | 02:46 PM
jonesEK's Avatar
no i havent
Yeah i bled the system already and checked the fuses ... I even had an extra relay laying around and swapped it in... didnt do a thing
Old Mar 5, 2012 | 03:11 PM
grumblemarc's Avatar
The Grumpiest
mine takes a loooooooooong time to kick on. Never overheats.
Old Mar 5, 2012 | 05:06 PM
hannslebo's Avatar
Try the paper clip thing...if it works then its your fan switch.
Old Mar 5, 2012 | 05:50 PM
Marvin1985's Avatar
You upgraded your cooling capacity and wonder why the fan ain't coming on???
Old Mar 5, 2012 | 06:21 PM
jonesEK's Avatar
thanks bro ill look up how to do it
thanks bro... it has never turned on.... since the install... even if i run it hard
Old Mar 5, 2012 | 06:26 PM
The Grumpiest
Nothing wrong with your fan.
Old Mar 5, 2012 | 06:35 PM
jonesEK's Avatar
thanks^
Old Mar 5, 2012 | 08:24 PM
BobbyRodriguez's Avatar
jump it
Old Mar 6, 2012 | 05:45 AM
motegicivic's Avatar
jump it to make sure it works. The fan typically only comes on if you are running a long time and then stuck in traffic and idling.
Old Mar 6, 2012 | 09:07 AM
dpetro1's Avatar
if you properly bled the system, the fan should have come on during the process. i would re-bleed until the fan cycles.
https://honda-tech.com/forums/showpo...85&postcount=3
Old Mar 6, 2012 | 09:10 AM
The Grumpiest
Actually we are assuming that his fan may have stopped working after the radiator was switched.
Was the fan working PRIOR?
Old Mar 6, 2012 | 12:30 PM
redm3turbo's Avatar
air in the system will prevent the fan from coming on.
Bleed the system
To jump it and check fan....go over to the passenger side Look down - you should see the thremostat- on top of that there is a connector. Unplug it, get a paper clip - plug each into each side. Turn car to accessory or fire it up, Does the fan kick on? if so its either air that needs to be bled, a bad fuse or relay, or a bad switch
If you just did a radiator.....I bet you need to bleed it.
Old Mar 6, 2012 | 01:14 PM
KINGVEM^^ED6's Avatar
Smh
Old Mar 6, 2012 | 03:49 PM
jonesEK's Avatar
thats what i thought happen
PAPER CLIP'D IT AND IT WORKS PERFECT
EJ8Squad919
Jun 30, 2014 06:46 PM
1989 Honda Accord
Jan 3, 2013 06:48 PM
turbo gsr
Jul 9, 2006 01:14 PM
FONK
Jan 12, 2006 03:03 PM
Kashi
Apr 13, 2005 07:09 PM
