B16 cam seal
Old Mar 1, 2012 | 03:12 PM
BKJJ77's Avatar
Default B16 cam seal
i need to replace my cam seal
i have seen that you can just pry off the cap and replace it on the newer civics
can i do that on a b16 or do i have to remove the heagasket to replace it
Old Mar 1, 2012 | 03:18 PM
D16SiHatch's Avatar
Default Re: B16 cam seal
The cam seal that's apart of the cam plug is i assume what you mean, not the cam seals behind the cam gears. You cannot pry it out, but no you don't need to remove the hg, why would you?
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/tech-article-b-series-cam-seal-replacement-2414973/
Old Mar 1, 2012 | 03:19 PM
Dc4LsTeG's Avatar
EK9
You don't have to remove the headgasket..you have to take off the cam rail and cap
Old Mar 1, 2012 | 03:24 PM
BKJJ77's Avatar
i got mixed up not the headgasket...im saying would i need to remove valve cover gasket to replace the cam plug
Old Mar 1, 2012 | 03:25 PM
Deetz's Avatar
Crazy Honda Guy
Bingo!!
Old Mar 1, 2012 | 03:26 PM
Dc4LsTeG's Avatar
EK9
Yes you'd need to remove the valve cover
D16SiHatch's Avatar
did you click the link!?
Old Mar 1, 2012 | 03:27 PM
BKJJ77's Avatar
or can i just pry it off like i have seen people do http://www.youtube.com/watch?v=kft_rAlFGe4
Old Mar 1, 2012 | 03:29 PM
Dc4LsTeG's Avatar
EK9
Are you listening to anything we are telling you?
Old Mar 1, 2012 | 03:32 PM
BKJJ77's Avatar
yah its just by the time i right a reply more people answer and then what i right dosent make sense
BKJJ77's Avatar
so do i need to buy a new valve cover gasket
Old Mar 1, 2012 | 03:42 PM
Dc4LsTeG's Avatar
EK9
Yes
94 IntegraLS
May 25, 2007 04:41 PM
DA is best
May 4, 2006 07:17 PM
TheWalrus
Jan 30, 2006 05:47 AM
B18CR-X
Oct 3, 2005 07:50 PM
cvc323
Nov 3, 2003 03:37 PM
