B16 cam seal
i need to replace my cam seal
i have seen that you can just pry off the cap and replace it on the newer civics can i do that on a b16 or do i have to remove the heagasket to replace it |
Re: B16 cam seal
The cam seal that's apart of the cam plug is i assume what you mean, not the cam seals behind the cam gears. You cannot pry it out, but no you don't need to remove the hg, why would you?
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/tech-article-b-series-cam-seal-replacement-2414973/ |
Re: B16 cam seal
You don't have to remove the headgasket..you have to take off the cam rail and cap
Re: B16 cam seal
i got mixed up not the headgasket...im saying would i need to remove valve cover gasket to replace the cam plug
Re: B16 cam seal
Originally Posted by Dc4LsTeG
(Post 46955723)
Re: B16 cam seal
Yes you'd need to remove the valve cover
Re: B16 cam seal
did you click the link!?
Re: B16 cam seal
or can i just pry it off like i have seen people do http://www.youtube.com/watch?v=kft_rAlFGe4
Re: B16 cam seal
Are you listening to anything we are telling you?
Re: B16 cam seal
yah its just by the time i right a reply more people answer and then what i right dosent make sense
Re: B16 cam seal
so do i need to buy a new valve cover gasket
Re: B16 cam seal
Yes
