Should I stick with this turbo or...
I currently have a GARRETT T3/TO4E 57 TRIM W/.48 A/R TURBINE, I want to evetually make around 350 horsepower to the wheels and was considering maybe going with a GARRETT T3/60-1. Which in your opionion would maybe be the best turbo to go with.
Lee
Lee
A t3/60-1 would definately make your power mark, but you could also just swap out your turbine housing for the larger .63 a/r or the .82 a/r. Both of those lager turbine housings would get you to the range you are looking for. What is the rest of your set up?
My setUP consists of
1.6 Dohc Vtec
Y1 Transmission with LSD
Arias 9.1 Pistons and Rings
Crower Connecting Rods
Nuformz Block Guard
Venom Fuel Rail
GSR Cams
STR Cam Gears
GSR Water Pump
GSR Oil Pump
Garret t3/t4 Turbo
Spearco FMIC
Tial 35mm Wastegate
Fmax Turbo Manifold
Fmax Downpipe
Dump Tube for Wastegate
HKS Racing BOV
Hondata 3b ECU
Rc Engineering 550cc injectors
Walbro 255cc Fuel Pump
Hyperclutch Stage 5
Honda Lightened Flywheel 12IBS
Accel Thunder Sport 8mm Plug Wires
NGK-R Plugs (7011)
MSD Modified Cap
MSD Blaster SS Coil
Lee
[Modified by ALLsh0w, 9:32 AM 10/10/2002]
[Modified by ALLsh0w, 9:47 AM 10/10/2002]
1.6 Dohc Vtec
Nuformz Block Guard
Venom Fuel Rail
GSR Cams
STR Cam Gears
GSR Water Pump
GSR Oil Pump
Garret t3/t4 Turbo
Spearco FMIC
Tial 35mm Wastegate
Fmax Turbo Manifold
Fmax Downpipe
HKS Racing BOV
Hondata 3b ECU
Hyperclutch Stage 5
NGK-R Plugs (7011)
MSD Modified Cap
MSD Blaster SS Coil
Lee
Lee
Lee
Lee, Brian here. I am Jimmy's (yellow CRX from RUSH) roommate. When did you get the hondata 3b? How is your car running? Have you dyno'd the car yet? If you need a custom chip burned, let me know and I can do it. I have a dealer kit and can tune them. Lata
Brian
Brian
I don't have the 3b at the moment, thats just what i will have. Don't have the car up and running yet. Just trying to maybe see if I might want to change turbo or not. I may just go ahead change out the turbine housing. Yeah when I do get the hondata I may need for you to burn a chip for me.
Thanks
Lee
[Modified by ALLsh0w, 6:12 PM 10/10/2002]
Thanks
Lee
JDM IN MY SOL
Aug 17, 2011 03:06 PM
