57 trim or 60 trim
Old Dec 31, 2007 | 12:47 PM
hbyrd8701's Avatar
Default 57 trim or 60 trim
hi honda-tech guy, my name lamont. this is my current setup:
91 honda civic hb
bonestock lsvtec
gsr cams
log manifold
35mm tial wastgate
50 or 57 trim turbonetics turbo
boost@10 psi
hondata s300
kteller 3in exhause to a apexi turbo 3in exhause
alright my future plan is to keep the bottomend bore stock and just put piston and rods in it. my car is a DD and sometime it may see the track. the horsepower that im gunning for for the streets is about 360+ and at the track my be 400+ horsepower. I'm not going jump on a certan turbo bandwagon, so i want to get a garrett turbo. the turbos that im looking at is the t3/to4e 60 trim w/.82 a/r,t3/60-1w/.63 a/r, and t3/to4e 57 trim w/.63a/r. these turbos is at cheapturbos.com.I'M NOT GOING GET ANOTHER TURBONETICS TURBO AGAIN cause i have my reason . i forgot to add that im going rev it at 8000 rpm. alright people what yall opioion on these units and who has them on there lsvtec. thanks
Old Jan 1, 2008 | 02:38 PM
hbyrd8701's Avatar
Default Re: 57 trim or 60 trim (hbyrd8701)
so 48 view and no replies, well thanks for the help..............................
Old Jan 1, 2008 | 02:41 PM
Schister66's Avatar
Man U FTW
The only real difference between the two is the compressor wheel. They use the same turbine and housings. The 57 trim is a 48 lb/min turbo; whereas, the 60 trim is a 50 lb/min turbo.
Basically the 60 trim is good for a little more top end power than the 57 trim, but you're going to have a little more lag w/ the 60. For your power goals, the 57 trim .63ar would be fine. I've seen it do 450whp on a piston/rod GSR and it still had more to give.
Old Jan 1, 2008 | 03:04 PM
hbyrd8701's Avatar
Default Re: (Schister66)
thanks for the help. i was just looking for a good turbo to get the job done and also having fun with my car. i just dont see the need for a big turbo for my goal.
Old Jan 1, 2008 | 03:20 PM
Schister66's Avatar
Man U FTW
Default Re: (hbyrd8701)
You had narrowed yourself down to a few good choices...all of which would suit your goals well without killing your budget.
...Its a shame that more people dont think of the trusty old 57 trim for builds like yours
Old Jan 1, 2008 | 04:11 PM
hbyrd8701's Avatar
yea
Old Jan 1, 2008 | 05:48 PM
bigb16's Avatar
57 tirm w/.63 a/r
integlspwr2k
Mar 19, 2008 04:02 AM
PeakBoost
Nov 17, 2005 07:27 AM
NoClassic
Sep 30, 2003 03:36 PM
T25 civic
Nov 13, 2002 09:28 PM
