96 4dr door to cabin harness clip
hey i know the is a well beat horse but after lots of searching i have yet to find the pinout for the clip at the drivers door i had lots of wires break off and they have broke off in the clip with no remnants of wire to go from , so a link to the wiring pinout would be awesome thanks !
is this for the harness in the door? or the floor harness? either way just go to the junkyard and get another plug, splice it in and go just make sure the plug is for the same year as your car. my floor harness was crapped out when i got it.
i could not find a pinout for the doors but a wiring diagram for the doors and the mirrors helped out alot. if you have your old plug and the new one side by side you can just match up the wires. will be fixing my plug this weekend.
if its for the door it would be easy enough to just replace the door harness it is not that bad .
all i need is the pinout for the main door harness at the plug in the jamb , it powers, windows , locks and mirrors , not tryn to be an *** but its an lx ! has power everything minus a sunroof ! i need to roll my windows down im a smoker
If the pins are broken off, your best bet is to get both connectors (with ample length of wire) from your local junkyard and solder the wires. I had to repair mine in my old '93 Civic 4dr.
well i over read some one asking some one else if they wanted it posted but the guy said he didnt need it so the other never posted it , if i pull the clip out of the other car im going to have the same issue al those car suffer from the same problems no sense in trying to resuse the same faulty wire set !
you are assuming every civic has that same failure alot do , but all? not the case.
imho it would be way easier to just install a new harness over trying to repair the pins in a broken plug.
but here knock yourself out. found it on all data. was a little lost using alldata but played with it today.
^ I hope you know that a new harness from Honda isn't going to be cheap. The OP's best bet is to solder in new pins(w/ wire attached) into the plugs.
i paid 8 bucks from a pick and pull for the same harness in perfect working order.
also i priced them from few local junkyards i use, 40 bucks delivered to my door
yup expensive.
yup expensive.
CaptivaBlue
10
Feb 27, 2005 10:24 AM
