Unhooking door wiring harness
I removed the speaker from the door to have access to the wiring harness connect on the inside of the door. Is there any trick to unhooking it? If I just keep tugging at it will it "let go"?
Re: Unhooking door wiring harness (hayabusa160)
I'm not sure I understand, it is like a bigger version of the same plastic connectors that hook to the power window controls?
yes I am, more specifically disconnecting it from inside the door- the part at the very front of the door- by reaching through the speaker hole opening
Re: Unhooking door wiring harness (CaptivaBlue)
There are little prongs/tabs that hold it in place. squeeze them and it will pop out or just push up on one and it'll come out. If you can't get it, get a flathead screwdriver
Re: Unhooking door wiring harness (Cuong-nutz)
remove this first the speaker wire clip. then stick your hand in there and push it out. there will be 2 tabs holding it in there it should be orange in color you should be able to see it
I still don't think we are on the same sheet of music, what I'm spekaing of is if you removed the speaker and reached in left (on a passenger side door) to the plastic connectior with all the wires routed through it. If I could take a pic it would be probably be worthless anyways because it's about 8 inches in the door in the dark.
with the door open from the inside of the car but on the outer shell of the door you have to have a flat screw drive and kinda pry up on the bottom of the clip.. theres a little lip there that wont allow it to break free... when your prying reach your hand inside the door and gently tug on the harness
Konner
05-07-2018 06:11 PM
