VSS Unplug no CEL??
Old Feb 29, 2012 | 04:25 AM
civicEX1995's Avatar
Default VSS Unplug no CEL??
hi guys
here is a question.
the saturday i was looking for a problem with my speedometer, it messuring like 40mph in idle.
when I was looking the speed sensor and disconnect it the CEL light on my car dont turn on, is that correct?
my CEL i working well, if i disconnect any other sensor it light on correctly, any suggestion?
Old Feb 29, 2012 | 04:58 AM
BryanM.'s Avatar
Resident Gearhead
Default Re: VSS Unplug no CEL??
The vehicle may have to be moving to set off a CEL.
Old Feb 29, 2012 | 07:20 AM
cvcrcr99's Avatar
Disconnnect the VSS and go drive around. The CEL will eventually come on.
Old Feb 29, 2012 | 03:22 PM
ok i will check that, but why if i disconnect the TPS, IAT, EACV or even the ECT the CEL comes on inmediatly?
Old Feb 29, 2012 | 04:11 PM
BryanM.'s Avatar
Resident Gearhead
The ECU is looking for a 0-5v pulse from the VSS. The VSS won't send the 0-5v pulse unless
the wheels are turning.
I've dealt with a couple of bad (OBDI) VSS, and the both wouldn't set off a CEL until a the
car was driven for quite a while.
Old Jul 20, 2012 | 08:04 PM
stevenson_18's Avatar
did you ever figure this problem out? Im having the same problem now at idle my speedometer is reading 40mph
Old Jul 21, 2012 | 01:21 AM
Former User's Avatar
If the odometer works, your speedometer is most likely bad.
Old Sep 13, 2012 | 09:02 AM
i replace the gauge assambly, now the speed meter is messure correct, thx!
Keo.
K Series
May 24, 2010 08:14 PM
Cruzan77
Jun 13, 2005 07:53 PM
Nick97hatch
May 8, 2005 09:15 AM
NegativeLift
Aug 4, 2002 08:02 PM
