s300 Vss Issue.
Old Feb 24, 2012 | 07:29 PM
tam4511's Avatar
Default s300 Vss Issue.
My ecu isn't showing a value for the vss, although my speedo is working fine. I replaced the vss during my engine build since it was messed up before. what could be the problem?
Thanks in advance!
Old Feb 25, 2012 | 04:03 AM
xenocron's Avatar
Default Re: s300 Vss Issue.
What chassis? What's the setup? Tranny is cable or hydro?
Old Feb 25, 2012 | 01:05 PM
tam4511's Avatar
Dc2, ls turbo, built bottom end, hydro tranny.
Old Feb 26, 2012 | 09:26 PM
tam4511's Avatar
anybody?
Old Feb 27, 2012 | 11:59 AM
Spunkster's Avatar
Probably a wiring problem. The VSS signal splits and goes to the dash and the ECU. The ECU is not getting a signal.
Old Feb 28, 2012 | 12:10 AM
tam4511's Avatar
Ok, so i should just follow the wiring and looks for a problem?
I need to take it to get tuned, but i cant get tuned for boost by gear if my ecu isn't getting a vss signal lol.
Thanks for the help.
Old Feb 29, 2012 | 06:02 AM
jrock1234's Avatar
Just wondering a update on if you found the problem or what's going on with it?
Old Feb 29, 2012 | 06:23 AM
tam4511's Avatar
I haven't had time to check it out yet, I should know by this weekend.
Luserkid
Nov 17, 2012 05:21 PM
Ruben19
Engine Management and Tuning
Sep 1, 2011 11:08 AM
duh blacksheep
18
Jul 23, 2005 05:41 PM
No
Nov 3, 2004 04:40 PM
hndakd
10
Feb 18, 2004 12:19 PM
