problem with data logging with USB cable
Old Jul 14, 2005 | 09:02 PM
duh blacksheep's Avatar
Default problem with data logging with USB cable
I cant get my computer to read the sensors. when i plug the usb cable to my computer, it sees in on com port 4. when its connected to the ecu, and im using ecucontrol data logger program, it says connected, but it doesnt read any values from the ecu. what do you guys thing it might be? i checked the wiring, its all ok. anything i should do software wise or whatever? is there like a common problem people face when it comes to this sort of stuff?
thanks
Old Jul 14, 2005 | 09:50 PM
3lue_by_u's Avatar
Default Re: problem with data logging with USB cable (duh blacksheep)
pgmfi.org will help a ton.
here is a link to their ECUcontrol forum
http://forum.pgmfi.org/viewforum.php?f=10
They have helped me through everything. I havent had a chance to datalog yet or I would help.
Old Jul 14, 2005 | 10:53 PM
Default Re: problem with data logging with USB cable (3lue_by_u)
do i have to chip my ecu before i can start data logging? my ECU is stock, i just connected the USB cable to CN2 and its not working on my computer
Old Jul 14, 2005 | 10:55 PM
GetawayInMoscow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3lue_by_u &raquo;</TD></TR><TR><TD CLASS="quote">pgmfi.org will help a ton.
They have helped me through everything. I havent had a chance to datalog yet or I would help.</TD></TR></TABLE>
Old Jul 14, 2005 | 11:26 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by duh blacksheep &raquo;</TD></TR><TR><TD CLASS="quote">do i have to chip my ecu before i can start data logging? my ECU is stock, i just connected the USB cable to CN2 and its not working on my computer</TD></TR></TABLE>
so is it supposed to work this way? i posted at pgmfi, but i dont think the forum moves as fast as honda-tech.
Old Jul 15, 2005 | 12:18 AM
JDMlyfestyle's Avatar
try swapping your TX and RX wires around.
do u have the driver installed properly?
baud Rate settings?
are you using USB or USB 2.0.. i had the same problem til i got a USB 2.0 port and it was all good from there.
Old Jul 15, 2005 | 07:04 AM
Default Re: (JDMlyfestyle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle &raquo;</TD></TR><TR><TD CLASS="quote">try swapping your TX and RX wires around.
baud Rate settings?
are you using USB or USB 2.0.. i had the same problem til i got a USB 2.0 port and it was all good from there.</TD></TR></TABLE>
I just doubled clicked the "USB DATA CABLE DRIVER" icon and it looks to be installed correctly. when i plug in the cable, the computer says its plugged in and ready to use. my settings are:
bits per second: 9600
data bits: 8
parity: none
stop bits: 1
fow control: none
is there anything else i can check? how do i know if its installed correctly anyways? when i go to device manager, it says "prolific usb-to-serial comm port (com4)
thanks
Old Jul 15, 2005 | 08:26 AM
BROKE.eg's Avatar
you have to have your ecu chipped with uberdata/crome and have the dataloggin enabled. otherwise you wont get any input from the ecu.
Old Jul 15, 2005 | 08:54 AM
Default Re: problem with data logging with USB cable (BROKE.eg)
cool thanks. I'm really excited to know that i still have a chance to get all of this to work, i thought i was stuck and wasnt going to get anywhere. i have to wait a week for the eeprom burner though =/
Old Jul 15, 2005 | 09:20 AM
Pioneer162's Avatar
Default O/T...
taken out of context as both a computer geek and a honda junkie that is funny as hell....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricer1 &raquo;</TD></TR><TR><TD CLASS="quote"> Hey mang muh ride not launching right.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle &raquo;</TD></TR><TR><TD CLASS="quote">do u have the driver installed properly?</TD></TR></TABLE>
Old Jul 15, 2005 | 12:00 PM
also dont forget to cut the J12 jumper wire.
Old Jul 15, 2005 | 11:21 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle &raquo;</TD></TR><TR><TD CLASS="quote">also dont forget to cut the J12 jumper wire.</TD></TR></TABLE>
i've never heard of this...why do we need to do that?
Old Jul 15, 2005 | 11:30 PM
the j12 jumper keeps all data in the ecu. but if its cut it allows the ECU to send out data through the CN2
Old Jul 16, 2005 | 07:25 PM
if i chip the computer, then i dont have to cut the j12 right? if i dont chip, then i have to cut j12?
Old Jul 16, 2005 | 07:33 PM
BROKE.eg's Avatar
Default Re: (duh blacksheep)
no you still have to cut j12. it helps with data transfer.
Old Jul 16, 2005 | 07:36 PM
Default Re: (BROKE.eg)
if you cut j12, can you data log without the chip? are there any side affects from cutting j12 besides not beable to connect through the serial port?
Old Jul 16, 2005 | 07:41 PM
BROKE.eg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by duh blacksheep &raquo;</TD></TR><TR><TD CLASS="quote">if you cut j12, can you data log without the chip? are there any side affects from cutting j12 besides not beable to connect through the serial port?</TD></TR></TABLE>
no, you still have to have it chipped with data logging enabled. and no there are no other side effects.
Old Jul 17, 2005 | 11:08 AM
cool, thanks you guys!
Old Jul 23, 2005 | 05:41 PM
EnzoSpeed's Avatar
I never cut J12. People always argue the theory on full/half duplex whatever, but I decided it was best not to cut J12.
EG6 Love
Engine Management and Tuning
16
Oct 9, 2011 09:13 AM
DelsolioGSR1996
Sep 5, 2006 08:50 AM
TehMan
Jul 5, 2006 03:47 AM
GWInquisitor14
Mar 20, 2005 08:04 PM
