B18C1 EK Swap, Motor Mount Problem
Old Feb 23, 2012 | 12:34 PM
GrimeyAssLos's Avatar
Default B18C1 EK Swap, Motor Mount Problem
Basically the rear t bracket (99 si) is about a inch off from the rear mount, I'm using hasport mounts anyone have this problem. Any help with this, I need to get this car gojng ASAP.
THANKS
Old Feb 23, 2012 | 03:11 PM
Deetz's Avatar
Crazy Honda Guy
Default Re: B18C1 EK Swap, Motor Mount Problem
It is possible you have either the wrong t backet, or mount kit.....
the EM1 Si rear t bracket is what you need, plus i believe you need an Si driver side engine mount post also.
Double check and make sure your Hasport mounts are for the EK chassis
Old Feb 23, 2012 | 09:38 PM
yes i got the 3 mounts from hasport and the bracket from HONDA
no clue what else it could be, ended up cutting and adding an extra inch to the bracket. and it works. motor sits straight, in a good position. thats why im tripping about it not lining up to the rear mount it was about an inch off.
anyone need a 99-00 si t bracket i got like 2, long story short i had 2 thought they were prolly the wrong ones bought one from honda they charging me a restock fee so yea!!
Old Feb 23, 2012 | 09:46 PM
98civdx's Avatar
Master Detailer
Does the car still have a EK subframe?
What Deetz meant is, are you sure Hasport didn't make a mistake and said you the inccorect mounts?
Old Feb 24, 2012 | 12:58 AM
Mikasa's Avatar
Aren't all rear mounts the same? For 92-00 civic and 94-01 integra. I got my Hasport mounts last month and the rear one had EGxx engraved on it
Old Feb 24, 2012 | 01:11 AM
im pretty sure they are the correct mounts.
would it be a possibility that they changed the crossmember?
(think thats what its called) where the rear mounts bolts onto.
Old Feb 24, 2012 | 08:50 AM
98civdx's Avatar
Master Detailer
IMO the rubber mounts are the same, however the T brackets are very much different.
Sure is, I've seen it before.
There are only so many reasons why this would happen, and that is one.
Do you have a front sway bar? What do the endlinks look like?
Old Feb 24, 2012 | 09:40 AM
DelSol-B18's Avatar
Well I deffinatly wouldn't rig up some mounts. Get the right mount the b series si one for ek. And make sure your mounts are for an ek
Old Feb 24, 2012 | 09:50 AM
Hasport's Avatar
the EGRR rear mount works in all 92-00 civics and 94-01 integras
sounds like someone switched out the subframe in which case you can just use a 94-01 integra 5spd rear "T" bracket
Old Feb 24, 2012 | 11:20 AM
Blasney's Avatar
From: On the road...generally in the central United States...
Yes. Even 'in-the-know' Honda/Acura parts guys and wrecking yards mix up rear brackets between Civics and Integras sometimes. If buying a used one, it's always best to know EXACTLY what car the part was removed from. I pick up Integra brackets whenever I happen across them at wrecking yards, and like to pull them myself so I know what I've got.
Old Feb 24, 2012 | 07:27 PM
twotonecivic's Avatar
sounds like a teg bracket is what you are looking for, they are like an inch longer than the em1 bracket. you must not have an ek crossmember.
Old Feb 27, 2012 | 09:56 AM
thanks everyone, i will try to go grab one from the junk yard , hope fully thats the problemi just dont want to be wasting even more money and it not be the problem, that already happened multiple times, guess if i want to do it right tho! lol
asocallocal
Apr 11, 2008 10:28 PM
redEH2
Sep 5, 2005 01:49 PM
slowazz97civic
Jul 20, 2005 04:41 PM
Hatchd
Jun 22, 2005 04:00 PM
