Sh H22a change over
I have an 01 sh and I'm going to replace motor and transmission..
Seeing how its an Sh I know that I have to replace the driver side axel with a base model prelude axel. But I want to make sure there's no surprises while I'm doing the swap, so is there anything else i should be aware of that will need to be changed as far as cross member, half shaft, rear mount exhaust piping etc..
If u guys know of anything please let me know! All help is most definitely appreciated!
Thanks!
Thanks!
Are you going to H22A4 SH block? If you're swapping one for one, there's no changes.
If you're going from SH to Base Engine and Trans- Need the inter shaft, and the axles because the SH's are different lengths.
If you're going from a SH to Base Engine only - You need the same stuff, plus an adapter plate to mount the base model inter shaft to the SH block.
If you're going to an older H22, you need a bunch of electrical stuff, I would suggest getting a newer H22 if possible.
Joesarfi
Jan 23, 2014 11:06 AM
samssf
Jun 20, 2004 09:53 PM
